05-13-2024, 11:25 AM | #15 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
05-13-2024, 11:58 AM | #16 |
Seems that way... also extreme conditions or really good driver is the key. I saw it in July with a pro driver in the seat. With the car's owner no issue.
05-13-2024, 11:58 AM | #17 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Following along as this is an interesting read. Plan on doing plenty of track days here in Texas this summer and will want to keep an eye on this. Would having your TCM tuned help alleviate this issue?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
05-13-2024, 12:01 PM | #18 |
05-13-2024, 12:13 PM | #19 |
My M6 ZLE will see all the track time and even if I did track the A10 Panther I doubt I would see it either.
Possibly what the OP mentioned about overfill had something to do with it. I've never seen a definitive cause yet. |
05-13-2024, 02:21 PM | #20 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
I don't think GM knows either. My dealer opened a technical case with GM about it, and since then they have not returned my calls.
05-13-2024, 05:06 PM | #21 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
It is transmission fluid level related. It has nothing to do with oil temperature. You can set the fluid level by coming off track hot and then immediately jacking the car up in the pits. Have a friend to speed things up. Do not get under the car without jack stands and gloves. Have a drain pan and remove the single bolt on the bottom of the pan with the car running. Anticipate a few ounces to a quart of fluid to come out.
If this doesn't fix the problem: 1. Ensure that the top and bottom coolant reservoirs are properly filled. Burp the cooling system. 2. Check if the transmission cooler is plugged with rocks or debris. 3. Replace the factory thermostat with a factory replacement or Katech 174 deg. (I had a factory t-stat fail)
05-13-2024, 05:24 PM | #22 | |
Drives: 2019 ZL1,2016 2SS, 2017 320d F30 Join Date: Dec 2021
The transmission got its own cooling with a single radiator. Its the one laying horizontal and I believe it does not have a thermostat. No clue if it can get vented tho nor if it's seperated of the fluid in the pan.
excuse my english
05-13-2024, 08:54 PM | #23 |
It just seems to be hitting a limit where heat is concerned. It does suck for anyone that can hit those limits.
05-13-2024, 08:56 PM | #24 | |
aka BeastZL1
Read the first part of my post. Sent from my iPhone using Tapatalk Pro
05-13-2024, 10:15 PM | #25 | |
Petro-sexual
I am not the one that seemed to have solved this. Member TravisLambert seemed to have solved this by substituting the auxillary blower heat exchanger with a dedicated engine oil cooler (C&R, I think). He left the OEM engine oil cooler (off the side of the oil pan) in-line (and think he was going to divorce it completely later and see if there was further improvement in temperatures), and did have upgraded blower/engine/auxillary engine heat exchangers (which his data showed almost no improvement) but after removing the engine oil load, all temperatures in that cooling circuit dropped considerably, and he observed no ill side effects of track use. He's got a big thread on it. I think he was mod'd with a 2650, and is an M6, so it's a little different, but might be useful. I didn't notice mod's but that could play a factor, too, if so. OP: I hope you find the solution
05-14-2024, 08:35 AM | #26 | |
05-17-2024, 05:12 AM | #27 | |
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter / fender tank, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, Elite E-2X catch can, and Griffin Motorsports front crash bar. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
05-17-2024, 07:07 AM | #28 | |
Petro-sexual
