01-28-2024, 07:42 AM | #15 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
I purchased the Katech also. I'm in a similar situation. I don't want to change the original unless I see the oil pressure drop because I'm still under warranty until December 2026. If the pressure drops, I'll have dealer install the Katech and may consider the cam if I'm out of warranty. I only have 2k on my car now, but I'm retiring soon and intend to drive the heck out of it. I just can't put that car in the parking garage where I work now. I've had a car that's had a hit and run and there are all kinds of stories of what goes on in that garage. The security guards are really little help when I had my incident. Accept for issuing citations. They're good at that...hmmm
01-28-2024, 07:47 AM | #16 |
ZL1 Driver
I would defiantly recheck after the next oil change. I've been running 0w/40, start at 39-41psi and drop to 29-31 at 200+ temp
01-28-2024, 08:26 AM | #17 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
This issue has nothing to do with the oil and you could have been using the "best" oil on the market and it would have still failed. its the subpar oil pump GM used for a certain amount of time on the ZL1s. There have even been a very few number of 2019 ZL1s that had their oil pump fail. You just lucked out and had a car that had this issue and it took a while to show. My stock 2018 has over 40k miles, driven of a mix of hard and light, raced hard and hasn't shown this issue. I still use the 5w30 oil recommended for my year model too. |
01-28-2024, 01:47 PM | #18 |
Drives: 2018 Camaro ZL1 NFG metallic Join Date: Aug 2018
Change done, at open loop it's just a hair over 20, my aeroforce gauge is showing from 20-5 with flashes of 30. When 4500rpm+ it climbs to 50+ then settles to 30 for 30 seconds then drops slowly to 23 ish.
01-28-2024, 03:34 PM | #19 | |
That right there is it saying I'm giving you all I got but I haven't got much left in me. |
01-28-2024, 04:37 PM | #20 |
Let me echo the statements of those who said it was time for a new oil pump. Do it now before you're suddenly looking at an engine teardown and rebuild project.
01-28-2024, 08:44 PM | #21 | |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I understand the frustration of wamting to keep the car or not, but if you are going to fix it, atleast you know the oil pressure won't be an issue again. And maybe u get alittle bump in power (and fuel lobe %) from the cam install. This way you can run a higher % of E. |
01-28-2024, 08:48 PM | #22 |
Owning SSes for 50 Years
With only 7k mile on my old 2018, I lost oil pressure very unexpectedly. After much expense, I found the grommet between the oil pump and pan was damaged...no way to know how that occurred but since I had never had the engine apart it must have been a factory defect. Replacing the grommet brought my oil pressure back to specs. Hope you find a cure for your issue.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
01-30-2024, 09:36 PM | #23 |
ZL1 Driver
Agreed. As Zach from Katech said in another thread, this is phase one of failure. Which is the initial crack in the vain of the oil pump.
01-31-2024, 01:49 PM | #24 |
Drives: 2018 ZL1 1LE Join Date: May 2022
I'm going to add another affirmation that it is time for a new pump. I was hyper paranoid about mine and had the pump replaced as soon as I noticed it idling at about 27 PSI warm (it honestly was a shot in the dark, I wasn't sure if it had actually failed or not, but my warranty was about to expire so I figured I'd take it into the dealer and see what they said). They ended up approving the work; low and behold, it was at the very beginning stages of failure.
Don't risk it. Get it done. Throw a cam in there while you're at it, if you're paying for the labor. Sadly I couldn't do that myself since mine was warranty work. |
01-31-2024, 05:22 PM | #25 |
My 2017 is way out of warranty so I would have to pay for replacement of the oil pump. I’m just keeping a check on it and my fingers crossed that it doesn’t fail.
02-02-2024, 02:41 AM | #26 |
ZL1 Driver
At temp what I show
02-02-2024, 01:52 PM | #27 |
02-03-2024, 10:28 AM | #28 |
PKG4U
That’s what my 2018 looks like at 18900
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
