#15 |
![]() Drives: 18 1SS 1LE SCCA FS, 99 WS-6, E46 M3 Join Date: Dec 2017
Update - the newer Foxwell NT650 Elite doesn't quite work correctly. The firing order was different (LR, LF, RF, RR) and it only activated the pump at on the right side. Lastly, it continued activating the pump well after the device indicated the procedure was complete.
Working with their tech support now. I've run several tests (with bleeders closed to save fluid), so hopefully the extra activations of the ABS pump doesn't put any undue stress on the braking system.
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
NT630 Plus here also. No issues. Great pedal feel.
#17 | |
OK, I purchased and tested the NT630Plus today with the same result as the NT650Elite:
The procedure runs as follows: LR, LF, RF, RR and the pump only activates on the right side. After the tool indicates the procedure is completed on the screen it continues pumping. Video for reference, of the NT650 and I didn't actually open any bleeders.
#18 | ||
![]() Drives: 2020 2SS 1LE Join Date: Jun 2020
Stock home version: v2.03.001 Updated home version: v2.04.002 Stock GM data: v3.17.001 Updated GM data: v4.05.001 I already have the car in the 'service position' so I will probably just go ahead with the automated bleed along with some manual ABS solenoid and TC solenoid activations (these seem to work as expected on the NT630Plus). I have also read that some cars activate all the ABS channels at once so really only one caliper needs to be bled while the cycle is running. Either way fingers crossed my soft/sinking pedal issue is resolved otherwise I'm throwing in the towel and it's going to the dealer. |
#19 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
Thanks for the tests and reports! So the bottom line here is that none of the aftermarket devices mentioned in this thread can perform the full flush/bleed correctly?
#20 | |
My theory is that the newer Foxwell software updates may have messed up the procedure. The latest word from the Foxwell tech support: From Foxwell Sales Team Fri, Jun 2, 1:28 AM (6 days ago) The engineer replied to me that due to the problem of the file, it cannot be modified temporarily. It is necessary to find a vehicle exactly like yours for testing, and then the specific file can be obtained. We will do our best to find the exact same vehicle as you, but the time is uncertain, we can refund you $20 for the waiting fee, what do you think? So I went ahead and ran the "wrong" automated bleed procedure, but haven't yet taken the car off the lift to test if the soft/sinking pedal is fixed. If this doesn't resolve it, I may look into the LAUNCH Creader Elite scan tool mentioned by Briland_1LE in an earlier post. Has anyone successfully used this tool for ABS bleed? And my last resort may be a Signature Corvette dealer who is used to large fixed caliper brakes and customer provided DOT4 race fluid.
#21 |
Well I struck out on my attempt, here is what I did:
One thing to note is that while bleeding the RR caliper on the automated bleed while the ABS pump and solenoid were cycling, I did get some very fine bubbles in the bleed line. Typing this up has me thinking I should have tried a second automated bleed, but considering the pedal feel was the same before and after I'm not sure it would have helped. Other things done while the car was up in air:
However, the end result is still a soft pedal so I think I'm throwing in the towel and taking it to a dealership. Might also look up some replacement stock pads because I'm in this far and might as well see it through... |
#22 |
UPDATE: running the NT630 Plus with the "wrong" procedure did not help my sinking/soft pedal either. Feels exactly the same as before. Didn't see any bubbles.
For now I would like to keep this thread going in case anyone can list a different scan tool (non-Foxwell) which has successfully performed the ABS bleed on a 6th gen. wilber - let us know if/how the dealer solves your sinking/soft pedal issue.
#23 |
I have an idea if the any of the NT630 Plus folks with ABS bleed success are able to help.
When trying to solve this problem with tech support in China, they had me replace 2 ABS files on the Micro SD card that is loaded in the device. The files that came on the NT 630 Plus are fairly new (1/11/2023) and they were replaced with newer files (6/2023) which didn't solve the problem, but it did slightly change the procedure. Would someone be willing to take the Micro SD card out of their NT630 Plus and check the date of these 2 files on their computer? If older than 1/11/2023, we could either request older files from China or maybe we share amongst ourselves. Here is the procedure per Foxwell tech support: Please take out the SD card, insert it into the card reader, connect the computer, open the SD, Vehicles-> American> GM-> Res-> Text Here is a Windows File Explorer screen shot of two files to look for (arrows):
#24 |
![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
I may be able to do that tomorrow, and if not I should be able to do it Wednesday. Things are a little crazy right now, but I'll do my best.
Matt Miller
2020 SS 1LE |
#25 | |
PS congrats on the trophy in Lincoln.
#26 |
I don't think this helps much, but my Foxwell NT 630 Plus came with files from 8/22/2022 and they exhibited the same unexpected behavior. Either way those files were wiped out when I updated via the Foxwell software on 6/7/2023 which also overwrote the created/modified/opened date stamp on my FX_SpeFLib.cbf and FX_SYS.cbf files to 6/7/2023.
I came across this thread where ZL1GMA indicates in Post #6 that he used the GM GD2 for his automated bleed and is seeing the same behavior that we are, so perhaps this is actually the proper behavior. ![]() In my stubborn attempt to avoid the crappy local dealerships I have since put in all new pads (Powerstop Z23s since they were a cheap test and I will use them as low dust daily pads) and since it was up I ran another automated bleed cycle and saw some more fine bubbles. My sinking pedal seems to have gone away but it still feels a bit soft and the pedal returns more slowly than I recall it doing before. Just to make sure it wasn't all in my head I went to a local used performance car dealer that has 3 SS 1LEs in stock and started and compared a couple of their cars to mine and they both had a softer pedal than I expected, but still felt marginally better than mine. I have some warranty work I need to schedule at one of the local dealers so I will shell out the $200 to have them bleed/flush when they have the car, just to ride this 'sunk cost fallacy' train to the final station. Will provide an update either way once I can get that scheduled and performed. |
#27 |
Thanks! That was more than I was expecting out of that weekend.
Matt Miller
2020 SS 1LE |
#28 |
Got my car back from the dealer yesterday after a factory bleed procedure and the brake feels the same as when I dropped it off, a bit softer than expected. Provided my own DOT4 fluid since it knocked $104 off the price of the bleed ($259 down to $155, yeesh).
However, I have noticed that after the new brake pads were put on and I did a light bedding the pedal firmness at the bite point improved drastically and continues to improve the more I drive it. My old pads were fairly worn and may have some pad taper going on which contributed to my issue. My rotors are also fairly worn so I'm probably looking at some DBA front discs and rear rotors and fresh stock pads before my next track session. I'm putting this particular issue behind me for now but wanted to update that the dealer bleed made no difference in my case, but a couple automated bleeds on the Foxwell and a pad swap did make a difference. |
