Roto-Fab
Old 12-29-2021, 10:24 PM   #15
ssonic2013
ssonic2013's Avatar
Drives: 2013 Camaro ss
Originally Posted by hrpiii View Post
those 'fog lights' are the DRL's. The SS's don't actually have Fog Lights on them.
I have DRL'S when will they turn on?
ssonic2013 is offline   Reply With Quote
Old 12-29-2021, 10:32 PM   #16
ssonic2013
ssonic2013's Avatar
Originally Posted by NOT A 45 View Post
That's true and false. DRL's replace the fog lights in models with HID headlamps. Vehicles with standard headlamps have fog lights
Right i have HID headlamps but the DRL'S don't seem to replace the fog lights. It's the other way around
Old 12-29-2021, 10:39 PM   #17
ssonic2013
ssonic2013's Avatar
Originally Posted by Badbubba View Post
If you have HID headlights, you most likely have the RS package. What color are your SS emblems? With the RS package, you do not have fog lights. The lights in those locations are the DRLs. The DRLs turn off when the headlights are on. You can make wiring changes to allow the DRLs to be on at night. What are you calling the DRLs in your post, the headlights?
When i set it to Auto only the bottom two lights the fog lamps come on. Nothing else comes on. The DRL" do not come on at all. That is why I'm confused. The only way i can get the DRL"S to come on is to turn the knob to parking. Then both fog lights and the DRL'S come on. I'm beginning to think someone rewired something..
Old 12-29-2021, 10:42 PM   #18
ssonic2013
ssonic2013's Avatar
Originally Posted by ChibiBlackSheep View Post
Like everyone already said, the fog lights are actually the DRLs and not fog lights on these cars. GM usually takes the headlights and runs them at 50% to be daytime running lights on most cars, but that is bad for the headlights that your Camaro uses, so the fog lights was their solution.
So what are my DRL'S light used for? Thank you.
Old 12-29-2021, 10:46 PM   #19
ssonic2013
ssonic2013's Avatar
I have HID headlamps DRL'S and fog lamps....
Old 12-29-2021, 10:48 PM   #20
ssonic2013
ssonic2013's Avatar
Originally Posted by SS_Dave View Post
Yep. Functioning as DRL's, not fogs on your model. If you'd like them to stay on all the time and be both "fog" and DRL, this will do it. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thank you i got it
Old 12-30-2021, 04:18 AM   #21
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
I think your calling the halos your DRLs. They are not. You don’t have fog lights. What you are calling the fog lights are the DRLs.
0stones0 is online now   Reply With Quote
Old 12-30-2021, 06:33 AM   #22
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
OUT OF THE OWNERS MANUAL..........
Front Fog Lamps
Object ID: 2543160Click here for detailed picture of the image.
For vehicles with front fog lamps, the button is on the exterior lamp control, on the outboard side of the steering wheel.
The ignition must be turned to ON/RUN to turn on the fog lamps.
#(Front Fog Lamps)
Press to turn the fog lamps on or off. An indicator light on the instrument cluster comes on when the fog lamps are on.
The fog lamps come on together with the parking and sidemarker lamps.
If the high-beam headlamps are turned on, the fog lamps will turn off. If the high-beam headlamps are turned off, the fog lamps will turn back on again.
For vehicles with High Intensity Discharge (HID) headlamps, the Daytime Running Lamps (DRL) replace the fog lamps.
Some localities have laws that require the headlamps to be on along with the fog lamps.
NOT A 45 is offline   Reply With Quote
Old 12-30-2021, 08:22 AM   #23
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
From my 1st reply. Color of your SS emblems? HID headlights with halos? What are you calling, thinking the DRLs are to be? Iirc, applying the parking brake will turn the DRLs off, at least for a manual trans.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 12-30-2021, 08:36 AM   #24
NOT A 45
NOT A 45's Avatar
Just look at the option label in the trunk....if it doesn't have T3U you don't have fog lights!
Old 12-30-2021, 05:00 PM   #25
Mr V
Mr V's Avatar
Drives: 2011 VR SS Vert
i bought the harnesses from gen5diy so both drl and halo's are on all the time.
Mr V is offline   Reply With Quote
Old 12-31-2021, 03:37 PM   #26
91Zman
91Zman's Avatar
Drives: '13 1SS/RS IOM white stripes
To strike fear in Mustang drivers when you are behind them...
91Zman is offline   Reply With Quote
Old 12-20-2023, 08:44 AM   #27
dlossing
Drives: Chevrolet Camaro
I have a 2010 SS, I purchased some P13 or P13W bulbs (cant remember, been 3 years ago) and the ones i bought wouldn't fit, it almost would, but didn't. When I look at phasetek all their P13 bulbs say for RS packaged camaro's, which I don't believe I have. Can someone point me to the correct location of just the standard 2010 SS DRI. Thank you in advance.
I do have the Square exhaust cutouts in the end, but I dont believe that makes it an RS
dlossing is offline   Reply With Quote
Old 12-20-2023, 09:13 AM   #28
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
P13W I ordered from Amazon to match my other lights, I bought different ones and they all fit.
maybe instead of DRL search for fog P13W
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
