09-15-2021, 05:47 PM | #15 |
Drives: 2011 Camaro SS Join Date: Jul 2019
Performance bolton for bolton has neither the l99 nor the ls3 pulling. They perform similar.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
09-16-2021, 05:31 AM | #16 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
I used to beat the early 6.1L cars
I guess that .3 L gave them enough power to overcome that 2 metric ton weight(4400lbs)
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
09-16-2021, 05:32 AM | #17 |
waiting at the tree
BTW I think the Scat Pack and 1320 models have a way better gear ratio than us.
09-16-2021, 11:09 AM | #18 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
That's why I wrote it. The LS3s have a bit more HP, plus minor tweaks, and I'm still not sure if I can compare to the Scat Pack. With the manual, I think I'm more than capable.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
09-16-2021, 08:43 PM | #19 |
25 hp more but its been known for years that the l99 and ls3 run door to door. Mod vs mod the auto does a little better.
09-16-2021, 09:07 PM | #20 |
09-17-2021, 02:59 AM | #21 | ||
My own experience. At the time when I bought my LS3 Camaro, an acquaintance brought an L99. He kept arguing with me that he had the most powerful V8 engine to go into it. On the contrary, I said that it has the weakest of the V8 engines on offer. No!!! So we went on the road. And it turned out the same as in this video.
09-17-2021, 05:26 AM | #22 | ||
waiting at the tree
From a roll? a manual has a huge advantage. Real drag racing is done from the dig. The A6 has the advantage from a dig....unless you want to hope you don't scatter parts on a 5k clutch dump
09-17-2021, 06:08 AM | #23 | |
I don't know how fast he was behind me. (From the dig). We do not play drag races in Europe. But it didn't take long for him to lose the length of the car. In any case, I do not deny the advantages / disadvantages of A6. I just want to say on the road LS3 shares will always be faster in the end than stock L99. Nearly 30 extra horses and less loss in the converter are simply noticeable.
09-25-2021, 06:48 PM | #24 | |
09-26-2021, 06:51 AM | #25 | |
waiting at the tree
It seems like it tries to accelerate in what ever gear it in. In sport mode its a different beast but sport and competition mode is where it really shines.
09-26-2021, 01:41 PM | #26 | |
https://youtube.com/shorts/CFzFgqRxCe0?feature=share This vid is from second but I tried to use the paddles for the entire run but but hit the limiter. https://youtube.com/shorts/H1xAwFheeaU?feature=share
09-27-2021, 03:28 PM | #27 | |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
09-28-2021, 06:21 PM | #28 |
What is auto shift....say you start off in second on a roll.....does it shift into 3rd on its own at redline? I just put it in D after the hit and let it shift on its own.
