03-06-2021, 08:05 AM | #15 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
I'd flip the air cleaner lid over.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
03-06-2021, 08:33 AM | #16 |
Drives: like an old lady Join Date: Jun 2012
sounds like a tune issue. my bolt on car has no hesitation anywhere.
03-06-2021, 11:14 AM | #17 |
Drives: 2019 ZL-1 Join Date: Feb 2009
All this started after your tune.....
2012 Yukon XL Denali w/ 6.2 AWD |
03-06-2021, 02:31 PM | #18 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
03-25-2021, 02:47 PM | #19 |
Drives: '18 SS 1LE Join Date: Jul 2016
Bumping this thread because I just read something about the 1LE.
Apparently, the 1LE has extra torque management (less throttle response) during low rpm? I read this is to help easing into the throttle when coming out of a turn or shifting. Can anyone confirm this is my issue? Or would a tune get rid of this? |
03-25-2021, 03:50 PM | #20 |
I have the same issue, it is actually closest to 2000-2200 RPM for me. My car did it when it was all stock, and still does it with a ported throttle body. The throttle body doesn't seem like it made much difference at that engine speed.
The biggest issue is in traffic, where you tend to keep going from lets say 1500-2500 rpm in second gear, I'm constantly trying to drive around the flat spot. If I'm able to accelerate a bit faster, I go right past it without a problem. It is most noticeable in lower gears, but I can still feel it in 3rd or 4th gears sometimes. By the time you get to 5th gear, you can't feel the flat spot anymore. I think it's just a poor factory tune. My car is a 2016 SS, M6.
03-25-2021, 07:46 PM | #21 | |
This sounds like the exact issue im having. I have a tune though. So maybe something with the 1LE? |
03-26-2021, 07:22 AM | #22 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
It's not just a 1LE thing. I have a '16 SS and have the same problem. Mine has done it since stock and now it's tuned with a Roto-Fab and Pray ported TB/IM. It's worse than ever now. On top of the hesitation I get very non linear throttle response up to 3K and then it takes off like a bullet. I can't even use rev match because it bogs out when hitting the gas after downshifting. I'm going to try another tune from a different tuner to see if they can smooth it out.
03-26-2021, 09:52 AM | #23 | |
03-26-2021, 10:03 AM | #24 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Are you driving it with the throttle in track mode? If so it’s doing what it’s designed to do. It will feel weak at lower rpm and then take off. Put it in sport mode and it will feel way punchier at low rpm.
03-26-2021, 10:23 AM | #25 |
BL1ZZRD
Sport or touring mode. Track mode really softens the throttle for track use.
03-26-2021, 10:56 AM | #26 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Could be tune-related. Mine is stock, no mods or tune. I use the Vitesse Throttle Controller on setting SP5 and experience almost no lag anymore.
Might be worth a try...
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
03-26-2021, 11:09 AM | #27 |
03-26-2021, 03:21 PM | #28 |
Drives: Camaro 1SS Join Date: Jun 2020
I'm not going to add any details because it would just be what has been mentioned before, but I have a stock 2017 SS Manual that I drive in Sport with rev match on (mostly) and I have noticed the same throttle response / lack of power issues as well when below 3k rpm.
My speed density tuned GTO is 1000x better in that regard. Night and day difference in throttle response. |
