Old 06-03-2020, 06:48 AM   #15
OB0001
2018 SS A8 11.85@117.06
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
+1 Rotofab with sound tube delete and dry filter
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake
OB0001 is offline   Reply With Quote
Old 06-03-2020, 08:49 AM   #16
RyanR623
Drives: SS A8, NPP, Red Hot
+125 for rotofab. Dozens of third party dyno's proving 11-14 rwhp depending on dry or oiled in a stock car. I chose the oiled because it flows better and filters more, but every 12,000 miles you'll have to cough up 49 bucks for a new filter. Unless you trust yourself not to over oil it on accident. Which i don't lol. Can't go wrong with either one.
RyanR623 is offline   Reply With Quote
Old 06-03-2020, 08:52 AM   #17
CamaroSS18
Camaro2SS18
Drives: 2018 Chevrolet Camaro 2SS
I have the GM CAI. It also has the dry filter and comes with the sound tube delete as well as a tune. This CAI will be covered under your factory warranty. Insulated closed box setup, instead of relying on the hood to seal.
CamaroSS18 is offline   Reply With Quote
Old 06-03-2020, 08:59 AM   #18
Mike Aruba
Mike Aruba's Avatar
Drives: 2016 2SS
+1 for the Rotofab with sound tube delete and dry filter.
Mike Aruba is offline   Reply With Quote
Old 06-03-2020, 09:15 AM   #19
RyanR623
Also, if you use the code lethal5 at phastek you'll get 5% off. It was the cheapest i could find.
Old 06-03-2020, 01:01 PM   #20
RockySS
RockySS's Avatar
Drives: 2016 Summit White Camaro SS
I like my K&N setup, I wold imagine it performs as well as any of the choices
RockySS is offline   Reply With Quote
Old 06-03-2020, 02:21 PM   #21
17camaroSS
17camaroSS's Avatar
Drives: Chevy Camaro SS
I’d go with stock with a green filter and velossa tech ram air. I ran stock with a modified lower box that I dimpled. Now I’m running an over the radiator ram air.
17camaroSS is offline   Reply With Quote
Old 06-03-2020, 02:56 PM   #22
enzia35
Drives: '16 Garnet Red 1SS
Oof...
'16 Camaro 1SS
'18 Miata GT
Old 06-06-2020, 08:36 PM   #23
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
Originally Posted by 6ixrosario View Post
What’s some good cold air intakes you guys have either herd of or have installed in your SS?
JLT.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 06-10-2020, 03:08 PM   #24
BlackKnight2SS18
Drives: 2018 2SS Redline
CAI Carbon Fiber with oiled filter. Best made box and looks killer too.
BlackKnight2SS18 is offline   Reply With Quote
Old 06-11-2020, 08:10 PM   #25
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
I've got the Cold Air Inductions and like it. However, if you think you'll be upgrading your throttle body size then Rotofab is the path to take as they have options to mix and match parts.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 06-20-2020, 07:41 AM   #26
HyperBlue16SS
Drives: 2016 Hyper Blue/ rallye 2SS
That sounds interesting. I'm a fan of the over the radiator ram air set ups. I had a VCM otr system on my Pontiac G8 GT. It was a massive K&N oiled panel filter. You could literally feel the difference. Where did you purchase this and how is the build quality?
HyperBlue16SS is offline   Reply With Quote
Old 06-20-2020, 08:47 AM   #27
Redlinez
Shifts under load
Redlinez's Avatar
If you want true dyno proven and track proven gains, Rotofab.
22 Suzuki GSX-S 1000GT blue
Old 06-24-2020, 09:29 PM   #28
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
Rotofab Dry All day long!! Great deal here! Proven performance!
https://gwatneyperformance.com/cart-share/joHd3/ref/2/
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
2016 - 2018 ss, 6th gen, camaross, cold air intake
