Old 05-23-2019, 10:07 PM   #15
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
So humbled by this:
https://www.facebook.com/14768620527...463251?sfns=mo
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 05-26-2019, 04:59 PM   #16
Tim M
Drives: 2018 Camaro SS 1LE
Chris - big kudos to you and your team.
I've participated in two OLOA's and they are a true testament of man and machine - skills to reliability. All have to align to succeed. I think one of the toughest competitions for the average joe...
Cool!
Tim M is offline   Reply With Quote
Old 05-28-2019, 09:53 AM   #17
Chris V
Chris V's Avatar
Cool!
Thanks Tim! It was such a bucket list item going into last year - then it immediately became the focus of my motorsports calendar. Which years did you do? Any plans of coming back?
You are so right, everything has to align. The gap between guys like me and the guys competing for the overall win is so huge too, and we're not that far back.
It's the best week in motorsports - where else do you get to hang out with a bunch of pro-racers and other famous-types?
From left to right:
Nitro Circus - John "Sheeny" Sheehan, Travis Pastrana
Reigning IMSA Prototypes Champion Eric Curran
My co-driver and myself
Lone Survivor Marcus Luttrell
Old 05-30-2019, 02:26 PM   #18
Tim M
Chris: Awesome image! My brother and I did 2001 and 2004 in my 1996 Corvette. 14th and 9th overall, respectively. It was automobile nirvana for the week as you comment.
The second event was 7200 miles in 10 days Tire Rack to Sears Point span (this included our transit to the start).
It is a grueling event that with one poor/missed session drops you chances significantly. Sleep deprivation and reliability seems to even the playing field - giving normal folks a chance.
I'd love to run again with the Camaro, but I've found myself across the pond for a few years. Glad to see the car is capable!
Definitely a feather in your cap...
Old 08-20-2019, 05:32 PM   #19
Chris V
Chris V's Avatar
Made the drive to NC to see Steven Rankins and dial in E85.
Look at those gains on a 100 degree day!
This car is rowdy.
Old 11-16-2021, 01:17 AM   #20
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
She's been sold (to me) and pulled apart after a charity lapping day at VIR... Couple pics of the car at the event below...
The car has been hiding and pulled apart while I searched for a new heart (the 6.2 and SC were fine, but I sold them both) that fit better with the car's purpose on track. I found one in Houston that's about 7 liters big and I'm hoping to have the car back and be doing some shake down tuning in the next 2ish weeks.
Specs are as follows:
HPR 427
GM LT1 Block 4.070 bore
Callies Crankshaft 4.100 stroke
Scat Rods 6.125
Wiseco Pistons 0cc
Wiseco tool steel, dual taper, pins
CID Cylinder heads by Greg Good
LT4 titanium intake valves
PAC 1207x springs w/ ti retainers
TSP roller tip rocker arms (non adjustable)
Comp 3/8 diameter 8.100"
Comp cam 257 / 267 .650 / .650 112+4 w/33% fuel lobe
Timing set - OE with 0 degree lockout and C5R chain
Cometic head gaskets 4.100 x 0.066
Johnson 2116 lifters
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 11-16-2021, 11:57 PM   #21
RideZX6R
RideZX6R's Avatar
Intake and TB on - need to get the map sensor extension in from fedex yet...
After that it's intake tubing/filter, catch can, tightening up the exhaust, fluids, front clip back together and a start-up tune to be uploaded and logged
-Seven
'24 911 T (ordered)
Formers...
Old 12-14-2021, 12:16 PM   #22
RideZX6R
RideZX6R's Avatar
https://imgur.com/DCg7jVa
Tuning begins today
-Seven
'24 911 T (ordered)
Formers...
Old 12-14-2021, 01:48 PM   #23
Tim M
Cool!
Old 12-14-2021, 02:20 PM   #24
cdb95z28
cdb95z28's Avatar
Is that a ZL1 nose/fenders or an aftermarket nose with the OE SS 1LE fenders?
Old 12-17-2021, 11:25 AM   #25
RideZX6R
RideZX6R's Avatar
Everything from the A pillar forward is ZL1-/ZL1-1LE besides the hood which is a very modded SS hood
-Seven
'24 911 T (ordered)
Formers...
Old 12-18-2021, 06:36 AM   #26
cdb95z28
cdb95z28's Avatar
Thank You
Old 07-25-2022, 03:39 PM   #27
RideZX6R
RideZX6R's Avatar
Took a while but got most of the tuning sorted out, part throttle below 2k rpms is shitty, but I can drive around it. Mostly track driving anyway.
So what's happened? Most driving it on track to shake off the mechanical cobwebs and see where the car needs changes to be reliable and fast, all while learning how to go fast after a long absence on track.
Been to Pocono once (Southeast course) and VIR twice in the last 6 weeks... here's a breakdown on what I've learned and I'll add some video too.
Couple quick pics... next posts will be individual track day updates...
-Seven
'24 911 T (ordered)
Formers...
Old 07-25-2022, 03:41 PM   #28
RideZX6R
RideZX6R's Avatar
Pocono:
Showed up with 3 year old SC3 tires, and brake fluid that was only used on track once before, but changed a year before and clearly had a little water in it. As a result, the car didn't have as much grip or brake as I'd have loved, but the limits were low so it was an easy way to get acquainted with the car on a shorter/slower track.
Highlights:
  • Forced my instructor (took one since I hadn't been to pocono in like 10 years and never on this config) to boil his brakes in his 997.1 on 3 year old SC3s
  • Held off a GT4 for 2-3 laps before I finally tried to go a little harder and looped the car
Lowlights:
  • All the stuff above about tires, brakes because squishy-ish as I added speed/heat
  • looped the car on the last lap of last session - gently into the grass though
  • was overwhelmingly slow
Playlist of PDR videos from each session, No pics from this one - https://www.youtube.com/playlist?lis...S_flE5c2Zlaq2f
-Seven
'24 911 T (ordered)
Formers...
