12-06-2017, 01:52 PM | #15 |
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2) Join Date: Jun 2016
As has been noted with a couple of excellent posts, a high volume station with modern pumps and equipment gives you the best odds that you'll fill up with fuel that has not been contaminated or broken down.
Top Tier is a set of quality standards that EVERY refiner in town meets at this point, that exceed EPA requirements for detergent additives in gasoline. In fact, at least in my part of the world, you would be hard pressed to find a gas station that does NOT sell Top Tier. I'm a terminal operator for one of the larger refiners in the Western US, who own or distribute to the biggest brands in Southern California. And the amount of persistent old wives' tales and "wisdom" about the connection between brands, oil, gasoline and quality is staggering. People will snub one brand in favor of crossing the street and paying $.40/gallon more for gasoline that was delivered from the same tanker truck, or came from the same refinery. When I was growing up, my own father refused to buy gas from the company I ended up going to work for, telling me that they made crappy gas from the lowest quality crude oil. I came to understand later that they really made great gasoline from crude oil from the Alaskan North Slope, which is to crude oil what filet mignon is to dinner. But because they were on every corner in L.A. and dimes cheaper per gallon that everyone else, it must be crap, right? |
12-06-2017, 02:10 PM | #16 |
Drives: 2016 2SS Convertible Join Date: May 2012
I believe the injectors on a DI engine are more sensitive to fuel quality than port injectors. The detergents in the fuel keep the injectors clean too.
You can believe them or not but there have been a few threads and web articles that discuss the problem on DI engines where the fuel doesn't immediately vaporize and washes oil off the cylinder walls to form a mixture that is prone to detonation. The articles claim during testing they found that certain combinations of fuel and oil additives are more or less prone to this issue. The article didn't name brands or additives due to the proprietary information. |
12-06-2017, 07:09 PM | #17 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I use shell personally. I used to work at a dealer way back when and when they started to put DI injection into cars a lot of the times, the injectors would go bad. (almost daily we would see this) we started to accumulate information from the customer, come to find out they were using speedway and BP gas. Just as a trial run, we asked the customers to try a top tier (speedway and BP are not) and never had a problem since. (yes we had to replace the injectors.) so I started to tell people to shop at a top tier such as shell. about a month later, I got a call from corporate speedway saying they could sue me for (I forgot the terminology) well since then, I did not mention anymore about going to shop elsewhere.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
12-07-2017, 02:27 AM | #18 |
you have to pay to be on the top tier list.
12-07-2017, 05:47 AM | #19 | |
12-07-2017, 07:33 AM | #20 |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
I been only using Shell 93' since i picked up the car and nothing else. So far so good. Here is a old thread i made back in 16' about what gas station do some use - http://www.camaro6.com/forums/showthread.php?t=464929
12-07-2017, 01:02 PM | #21 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I'd ask the manager of the station if the in ground tanks have been replaced and how often they get filled. I'd think that a station that sells a lot of gas and has newer equipment would likely average a higher quality gas.
12-07-2017, 02:21 PM | #22 | |
Drives: 2019 CTS-V Join Date: Feb 2016
12-07-2017, 02:36 PM | #23 |
Drives: 2017 2SS, 2000 Trans Am Firehawk Join Date: Jun 2014
I use Sunoco because it's a new station and close to my house. My Firehawk can't stand Kwik Fill Gas. Other stations are hit and miss so I simply pay for what works in my car with no issues. The Camaro does not seem to care. 17 year old car vs 1 yea old.
I am a sarcastic SOB.
12-07-2017, 04:17 PM | #24 | |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
12-07-2017, 04:56 PM | #25 | |
Drives: 2017 Camaro SS M6 Join Date: Apr 2017
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
12-07-2017, 06:28 PM | #26 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Costco is a Top Tier gas provider: http://www.toptiergas.com/licensedbrands/
12-08-2017, 12:08 AM | #27 | |
Drives: X-15 Velocipede Join Date: Mar 2008
Why TOP TIER Detergent Gasoline?
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
12-08-2017, 03:54 AM | #28 | |
Drives: Love the one you're with Join Date: Sep 2009
