#15 |
I found this on ebay. seems easy to install. shipping insane but still nice
http://www.ebay.com/itm/16-17-Chevro...xXU7fK&vxp=mtr
#16 |
![]() ![]() Drives: 2016 1ss Camaro Join Date: May 2016
yes those are a different brand and there not a replacement sideskirt just a splitter
#17 |
![]() Drives: 2017 1ss1le Join Date: Feb 2017
From thatgmpartsguy.
#18 | |
![]() Drives: 2008 corvette Join Date: Jun 2016
#19 |
Curious as to where the $2220 for parts came into play? lol
Regardless,
I have the 2016-2017 Camaro V8 Duraflex GMX Body Kit - 4 Piece Kit in stock...Special Forum Price $710 plus shipping to your location! Please be advised that you will have to have this professional installed by a body-shop that has extensive experience installing aftermarket products. Let me know if there is anything else I can do. http://extremedimensions.com/2016-20...t-4-Piece.html
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
#20 |
![]() Drives: 2017 fifty camaro Join Date: May 2017
Sorry new to this. Is their any skirts that actually mount in the factory position? Take off and mount on the new ones?
#21 |
The gap where it tapes drive me insane.
#22 |
Yep, this will fit on your OEM Sideskirts
Please see the link below as well as the picture!
This can be sold separately and will fit on your OEM side skirts. Price on just the GMX side skirts $244.30 + shipping ! http://extremedimensions.com/2016-20...s-2-Piece.html
Andrew Bettridge
#23 |
Any install videos?
#24 |
#25 |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Watch Sledge's video on installing the GM sides.
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
#26 |
![]() ![]() Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
Just a heads up on the duraflex products... I am not happy with mine and was told that this is acceptable flaws in the product and a body shop can fix them no problem.. DO NOT BUY the duraflex product with the intent to install yourself.. I wish I had gone another route because after how much it cost to prep and fix all the issues in the duraflex itself then paint and install... you may be better off going with the GM kit.
Advantage to duraflex is you get to do what you want and alot more style options but just be prepared.. My spoiler Line in the back is wavy really bad and there were small chunks missing out of the sides skirts when I emailed and asked about it.. the response was this is fine because you will need a body shop to do it anyways they will fill and fix.. but fill and fix cost extra money. I am not trying to deter anyone away from their products but just be full aware of what you are getting into. I get my parts back on friday and we will see how well the body shop was able to "fix" the issues. I will post pictures. Here is what should be visible for duraflex products you should not have to dig for this information. Keep in mind this kind of prep is expensive @ labor cost per hour. so remember that when comparing higher prices from other companies with stuff that is ready to install. Duraflex brand aerodynamics will follow traditional FRP (fiberglass) preparation where every visible inch of the finish will need to be sanded to eliminate any blemishes including gelcoat chips, scratches, pin holes etc. By block sanding the finish you will be able to see the straightness of the product as well as anything that will need to be glazed with finish body filler. The finish on Duraflex brand aerodynamics is just a basic primer coat that was used to help the part pop free from the mold when it was originally laid up. This is not a surfacing layer intended to be directly painted or to be installed without paint as it lacks UV protection. The more time spent on prep the better the finished install and quality of the paint job will be. Once the part has been totally prepped we suggest using a high build primer suitable for FRP to be sprayed and wetsanded before the base coat and clear coat is applied. High build primer will provide a thickness of finish applied on top of the part that can be easily sanded and checked for perfection.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com Last edited by Dustya; 08-10-2017 at 10:19 AM. |
