05-11-2017, 02:55 PM | #15 |
Drives: 2017 ZL1, 1995 Trans Am Join Date: Jan 2017
Plus you have to have your foot completely off the gas pedal correct?
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof |
05-12-2017, 09:02 AM | #16 | |
I used to be Dragoneye...
Awesome!! |
05-12-2017, 04:02 PM | #17 | |
Holding the shifter back or left tap for a couple seconds actually goes max to 6k or even more depending on your speed. So the two are a bit different and both have good application. This A10 is unreal... |
05-12-2017, 06:15 PM | #18 |
Drives: A10 LT4 Join Date: Aug 2016
05-16-2017, 04:48 PM | #19 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Need help understanding this feature. If I am driving say 45mph in 5th gear as an example, what gear will it drop to by doing this? Is there a limit to what mph this works with? Just trying to figure out how many gears it drops to.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
05-16-2017, 04:54 PM | #20 |
Daily Driver 24/7 365
Drives: '15 CRT 2SS/RS/1LE Join Date: Jul 2015
This worked on my 2014 automatic V6 5th gen as well, mike, I'm glad they kept that feature in the A10!
NPP Fuse Pull, Z28 CAI =
Previous Rides: 2005 Magnum R/T A5 CAI, Cat-Back 2014 RRM Camaro 1LT/RS A6/NPP CAI Follow Me On Instagram! |
05-16-2017, 04:54 PM | #21 |
2nd gear
05-16-2017, 08:12 PM | #22 |
Did not know that. But when you have 10 gears it's definitely a plus to have.
05-17-2017, 11:24 PM | #23 | |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
When I first tried the accelerator tap, I was rolling around 60, which from my tests today, drops to the same gear as holding the paddle. Below that speed, the paddle dropped 1 gear lower every time. Sometimes the next lower gear would be an advantage from an acceleration point, but sometimes it wasn't. Either due to being so high in the revs (6k plus) that you would hit the rev limiter as soon as you nail the gas, or due to way less traction in the lower gear. I really enjoy both methods, and have to say, dropping that one gear lower at the lower speeds, makes things very interesting. I was slipping, sliding, and quickly clicking off gears left and right! Very fun! This car freaking rocks!! Thanks again for clearing up the hold down feature.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
05-17-2017, 11:30 PM | #24 |
As stated already, at 45 mph, it will drop to 2nd gear. I don't think there is any speed limit for this feature. I've used it at 80 mph, and it will drop from 10th to 3rd gear!
05-22-2017, 11:49 AM | #25 |
05-22-2017, 07:06 PM | #26 |
One more question since I still haven't tried it yet. Once it downshifts you have to paddle shift for all the upshifts, right?
05-22-2017, 09:15 PM | #27 | |
In auto when you tap the throttle to the floor, it goes to 4k & then you can get back on it. |
06-23-2021, 06:18 PM | #28 | |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Mosaic black 2018 Camaro 2SS A8 (sold) Last edited by MakCamaro; 06-25-2021 at 11:06 AM. |
