11-11-2016, 04:34 AM | #15 | |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Not a scientist just using simple common sense is all
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
11-11-2016, 05:58 AM | #16 |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
Today my car wouldn't start.
Unplugged throttle controller Put gas in car Car now starts Must be throttle controller Heads up everyone! |
11-11-2016, 07:20 AM | #17 |
11-11-2016, 12:20 PM | #18 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
11-11-2016, 12:32 PM | #19 |
Drives: 2016 Bright Yellow 2SS A8 Join Date: Jul 2014
If the code is P2138-Throttle position sensor 1-2 correlation then it's definitely the Vitesse. Had this happen to me. Make sure you installed it properly. If you need to reprogram it, hit buttons A and B at the same time for a few seconds and you will see a countdown. The first number that pops up will be the low voltage reading. Hit A to accept. Then depress the accelerator pedal as far as it will go. The reading you see on the controller will be the high voltage reading. Continue to hold the pedal down and press A again. You're done. You're check engine light will remain on for about 5 drive cycles and then go away. Also make sure your throttle body is clean. If you have VMAX ported throttle body and it's just a bit dirty, it doesn't like to play well with the controller. Had this happen on both my 5th and 6th gen now. I always make sure to clean my throttle body after every oil change.
11-11-2016, 12:41 PM | #20 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
11-11-2016, 12:45 PM | #21 |
Yup. You're right sledge, but I think the OP mentioned he did that already. Everything else I mentioned would be after the reset.
11-11-2016, 01:04 PM | #22 |
Drives: 2018 Hyperblue Camaro 1SS/1LE Join Date: Feb 2015
11-11-2016, 01:07 PM | #23 |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
One reason why I don't mess with it.. don't want the hassle of the Vitesse throwing codes. For those of you that don't have probs, glad it's working out for ya.
11-11-2016, 01:17 PM | #24 | |
I would like to note; the eco setting on the controller does make this car more of a daily driver. Which honestly is the primary reason I run the controller the throttle delay we hear about is barely even recognizable as a delay. |
11-11-2016, 03:22 PM | #25 |
Drives: 17 SS 1LE Join Date: Dec 2015
11-11-2016, 03:49 PM | #26 | |
Drives: 2016 2SS Red Hot Join Date: May 2016
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter |
03-30-2017, 09:11 PM | #27 |
Drives: 2023 BMW M4 Competition Join Date: Dec 2012
If a code is thrown due to the Vitesse, is that something the dealer could potentially see, or is that data erased when you unhook the battery?
Has anyone noticed better fuel economy with the eco setting?
2023 BMW M4 Competition (daily)
2022 ZLE M6 (weekend toy) 2022 BMW X3m40i Past: 2022 Tesla S Plaid 2020 Shelby GT500 sold 2019 Hellcat Redeye-traded for new GT500 2019 ZL1 A10 - sold (meh) 2019 Tesla M3P 2016 Hellcat Challenger - A8 sold but never forgotten 2016 Camaro 2SS M6 2014 Mustang GT A6 2012 Mustang GT M6 "brembo" 3.73/FBO 2012 Camaro SS L99 (Wife's)- slow |
03-30-2017, 10:22 PM | #28 | |
Drives: 16 2SS Join Date: Jun 2016
No the dealer cannot. Look up ponyscorpian's thread about this. They will think it's an issue with the accelerator relay/assembly and replace it (which wasn't necessary). Just happened to me. All I had to do was unplug it, 5 restarts, all codes go away and replug and recalibrate. It's really not that big of a problem and has only happened to me once in 6 plus months. These newer cars have so many safety mechanisms to prevent it from actually screwing something up Sent from my iPhone using Tapatalk |
