02-06-2016, 01:18 PM | #15 |
Drives: 2017 Camaro 2SS, 2011 Camaro 2LT Join Date: Jan 2014
02-06-2016, 01:21 PM | #16 | |
I honestly don't know if they put the car back on the lift because I went back inside with the service advisor after they took my car back in the shop. But only took them like 5 minutes to take my car back in the shop and come back out to say it's not their fault, so I doubt they put it back on the lift, but I am going back on Monday to have them check it again. Sent from my iPhone using Tapatalk |
02-06-2016, 01:29 PM | #17 | |||
Same here man. Not in this situation Quote:
Exactly, and I sure use remote start all the time to warm up my car before leaving anywhere. Quote:
Checked the oil level the same day and it was fine. Going back to have them recheck the car. I understand coincidences, but not in this situation. Quote:
I'm out of warranty at 104,xxx miles currently. Mostly highway miles from traveling back and forth to Arizona and California a lot. But I'm going back to the dealer on Monday to check it out. Sent from my iPhone using Tapatalk |
02-06-2016, 01:34 PM | #18 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
I had a car I liked very much, a '97 Riviera. One day while I was stopped just before a rotary (traffic circle), waiting for a break in traffic to enter, a van plowed into me from behind.
Every light on the dash was on following the hit, every single one. Security, high beams, Check Engine, washer fluid low, charging system, e-brake, high temp, garage door opener, you name it, if it had a bulb it was illuminated. I had quite an argument with my insurance company about that: they declined to pay for that fix. They told me it was not possible that this was caused by the impact. A coincidence, they said. I started feeling that I was talking to an idiot. I asked her to do me a favor: Describe to me why that cannot happen. She said, 'the car was not hit near those electronics'. "Really?" I said. "Interesting. Throw your computer out the window and then tell me if it works. It should right? The circuit boards weren't hit." Long story short, the impact in the back had made a wire bundle come loose under the hood, and it was just long enough to have some wires hang down to an exhaust manifold. I'm not saying the OP's shop did anything wrong. I'm saying that 1) coincidences are pretty rare even though they do happen, and 2) cars can do some odd things, and it is not in the shop's best interest to conduct an exhaustive investigation to find out if they were actually at fault or not.
02-06-2016, 01:35 PM | #19 | |
I did the fuel injector service back in October or November and the car was running perfectly since I got that service done. I say it ran even noticeably better after doing that service. Everything felt so much smoother with the car and no CEL. Going back to the dealer on Monday to have them check out my car again. Sent from my iPhone using Tapatalk |
02-06-2016, 01:51 PM | #20 | |
wow, crappy situation you had there and feel your pain. Perfect analogy too. Going back to the dealer on Monday and will see what happens. Sent from my iPhone using Tapatalk |
02-06-2016, 02:25 PM | #21 |
El Duderino
Service department is trying to blow you off. Obviously, they did something to cause that. Do you have a record of the mileage of the service and the mileage of the code? Make a note of it and keep bugging them until every other possibility is exhausted.
And as was suggested above, try another dealer or an independent for a second opinion. JMHO
I bowl. Drive around. The occasional acid flashback.
02-06-2016, 03:08 PM | #22 |
Drives: 2014 2SS/RS Join Date: Jun 2013
In 5 minutes, they didnt put it on the lift.
Theyre not trying to blow off OP. o2 sensor codes are not a big deal. If OP wants to clear it himself without a tech2, just unplug the battery w/ the headlights on for a little bit. If the code keeps coming back, then bring it in. If you go into the stealership and tell them, "look, i've reset the code and it comes back a million times since this maintenance" then they'll give you the time of day. |
02-06-2016, 04:04 PM | #23 | |
Yes I have the mileage of the service and mileage when CEL turned on. I will be going in on Monday and will talk to my service advisor about it. I always go with this 1 service advisor every time I go in for oil changes / maintenance work. If he doesn't try to work things out with me then I'm going to ask to speak to the manager. I will also try getting a second opinion as well if he doesn't try working things out first. Sent from my iPhone using Tapatalk |
02-06-2016, 04:15 PM | #24 | |
It's the fact that I paid almost $500 for these services to get done and another issue happened during the process which they don't want to own up to. Sure you could say I could complete my own maintenance stuff, but I'm just not savvy when it comes to car work. I don't mind paying as long as the work gets done right and that's just the way my situation is. If you can do your own work to your car then props to you. It's a big deal if they caused the issue as well as if I need to pass emissions. I also didn't pay for the 2LT model for the remote start not to work. Will just see how it goes and will keep this thread updated. Sent from my iPhone using Tapatalk |
02-06-2016, 04:17 PM | #25 |
Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
If they say no, I always say I will call Corporate. One time, I told them not to wash my car, they washed it and of course there was scratches all over it. He tried to tell me they were there before and they have proffesional detailers working in the back and they would never do that. I walked back there and it turns out it that some young kid drives your car through a dirty automatic car wash to get it washed. After I told the manager and made him realize that he lied, and also told him that i will call corporate, he told me they can detail my car. I said no, I dont want you guys doing it and i ended up taking my car to a good detailer and they paid the bill.
02-06-2016, 04:19 PM | #26 | |
El Duderino
02-06-2016, 04:24 PM | #27 | |
I feel your pain. I always say no to the included car washes too because I've seen how the cars are washed and I don't approve as well. They do go through those automated machines that scratch and swirl your car. But good idea on calling corporate if they don't want to work things out with me. Glad they worked things out with you. Will see how it goes on my end. Sent from my iPhone using Tapatalk |
02-06-2016, 06:45 PM | #28 | |
"Catharine"
Drives: '11 2SS/RS LS-3 IOM/IO vert Join Date: Mar 2011
OP, I doubt it's a coincidence too. Could have been anything, even just bumping an O2 sensor with a wrench could do it, I've read where those things can be sensitive. Good luck and please keep us posted!
