01-25-2016, 10:51 PM | #15 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
Thanks alot man
CAMARO
Consult your doctor before taking Camaro Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help CAMARO Bringing excitment back into the Garage |
01-26-2016, 07:47 PM | #16 |
Drives: 2010 2LT Victory Red Join Date: Sep 2011
Did not have to loosen fuel tank straps at all , but I did loosen the screw on the other end of the charcoal canister( Canister is slotted on that end ) to give me a little more working space
01-26-2016, 07:51 PM | #17 | |
02-11-2016, 10:31 AM | #18 | |
Drives: 2010 Cyber Grey Join Date: Feb 2010
Odd question.
My car was high jacked by my son today so I cant go out in the garage right now and pull the tire. I would rather invest the time in beer and swear words than pay the dealer $729.00 bucks to replace a part that I think was defective to start with. I intend to pull the rear wheel today and see if I can get my hand in there. Your the first person I saw to say it can be done. I used to be a mechanic back in the late 90's but I am right on the fence on this one. As I get older I find it easier just to pay the piper. Anyway thanks for your input. |
05-02-2016, 03:48 PM | #19 |
Drives: 2010 Camaro RS Join Date: Aug 2015
Just wondering. Did you ever get to fix this issue your self? I am planning on attempting this since I have the same P0449 code on my 2010 RS. Doesn't hurt to try.
05-02-2016, 06:58 PM | #20 |
Drives: 2010 Inferno Orange Camaro Join Date: Mar 2011
Just did it friday. I will say that you can get your hand in there without dropping the subframe, but it is 100 times easier if you do. I tried the not dropping method, and it was miserable, I could barely get past my forearm. Eventually just removed the 4 subframe bolts and lower strut bolt on the passenger side. Used my floor jack to support the cradle. It was like night and day.
05-02-2016, 07:12 PM | #21 |
Ok i see. Was it because your arm wasnt long or slim enough? just wondering since I am planning on doing this really soon.
is this the part you got? 19329627-solenoid Either way ill rather do what will take care of the job. Did you have to get it realigned? |
05-02-2016, 07:38 PM | #22 |
Yea, that's the part number. It's not so much getting your arm in there, it's being able to remove the piece from the metal tab as well as undoing the spring clamp. If yours is anywhere as stuck as mine was, there was no room for me to have my hand and tool in there at the same time. Didn't take it in to be realigned.
05-02-2016, 07:58 PM | #23 |
Drives: 2010 r/s switchblade metalic Join Date: Oct 2011
po449 dam you GM.......
05-03-2016, 09:10 PM | #24 | |
Previous Vehicles
1970 Impala 2D 350/300 1972 Buick GS 350 1967 Pontiac Firebird 326 1969 Chevelle SS 396/375 I really miss this one 1966 Chevelle SS 396/350 1978 Plymouth Fury 440 1982 VW Scirocco ( Got married ) 1987 VW Scirocco 1992 Ford Taurus V6 1996 Dodge Intrepid 2002 Dodge Intrepid 2002 Mercedes ML500 2010 Camaro 2LT |
05-03-2016, 09:14 PM | #25 | |
Previous Vehicles
06-28-2016, 08:54 AM | #26 |
Drive It like its stolen
Another victim of the P0449
Getting the CEL P0449 in my 2010 V6 for the past 2 weeks. I've cleared it and checked everything I could thing of. CEL came back. It has 41K miles. Guess its my time to have some fun. I have the part but its going to the dealer to see if I can get it covered. I know, I'm going to be out $100 for them to read the code and I'll end up doing the repair myself.
Drive it like it was meant to be driven !
09-05-2016, 02:57 PM | #27 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
09-15-2016, 10:26 AM | #28 |
Just took care of my P0449 on my 2010 V6 and happy to say all is well.
I removed the rear tires, removed the exhaust, and dropped only the right side of the sub frame. After 3.0 hrs the bad solenoid was out. I did take pictures and can do a write up if anyone is interested. (removing the exhaust took more time than anything, putting it back on was a trip too) Even changed the rear diff fluid while I was in there..
Tags |
cel, emission, p0449, purge, solenoid |
