01-10-2016, 08:50 PM | #15 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
This is mine, vvt ss1, L99 with LSA Supercharger... Great idle...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
01-11-2016, 12:11 AM | #16 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
This is my opinion and its all relative. I personally can DD a nonoverdrive car with a full spool but I know there are guys out there perfectly satisfied with a LS9 cam.
Torque starts to take a good drop below 3500rpm when you go over 228 or so intake duration. Yes overlap plays a part too but Im more speaking on low end torque. |
01-11-2016, 09:37 AM | #17 |
Drives: 2015 Camaro SS Join Date: Sep 2011
My cam spec is 226/236. I pick it up Wednesday and it sounds like im right on the edge of drivability, guess I will find out then
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
01-11-2016, 01:26 PM | #18 |
If its cut tight like the ASA yes but like I said its all relative.
01-11-2016, 02:28 PM | #19 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
My current blower cam is a 227/235, .641"/.649", 114 LSA from TSP on the 416, which is a larger motor but lower compression. The cam I had in the stock motor was 225/230 .629"/615", 114 LSA with stock compression ratio. It was easy to tune, as it had a slight negative overlap @ .050" lift. The new one has 3 degrees positive overlap, just like the one you are asking about, and was pretty easy to tune also. For me, right around that area of overlap is the compromise area for a DD. I've tuned cars with 15 degrees or more overlap, that is definitely not DD territory. I never recommend a cam with more that 5 degrees of overlap for anyone who primarily DDs their car, unless they specifically say they don't care about the harshness.
01-11-2016, 05:01 PM | #20 | |
Drives: 14 1LE Join Date: Jul 2013
01-11-2016, 06:38 PM | #21 |
With the first cam, I could drive at 45 mph in 6th gear with no surge at all. The cam you described would have 2-1/2 degrees more overlap, so you may start to see just a touch of surge at high gear/low rpm, but I doubt it. But I definitely can recommend the 225/230 cam from TSP, which is why I ordered the second cam from them as well. Not sure what lobes are being used on the cam you originally asked about, but the TSP cam is really well-mannered and I didn't see much increase in valve train noise.
This is only my opinion, but I would do the 225/230 cam before I did the 227/235 on a N/A build, even though I used it as a blower cam. I know many people would recommend more exhaust duration, but increasing exhaust duration either means you would have more overlap, or would have to run a smaller intake lobe, assuming the LSA stays at 114. The 225/230 is actually the smallest LS3 specific cam TSP makes, because it behaves nearly stock, due to the 1/2* negative overlap. |
01-11-2016, 08:01 PM | #22 |
I have a 232/240 .626/.626 112LSA and it drives pretty damn good I daily drive it. No complaints on drivability really
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
01-11-2016, 08:52 PM | #23 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
Very similar to mine and if you are getting who I think you are to tune it, you are gonna love driving it. I do mine, even in Atl.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
01-11-2016, 09:04 PM | #24 |
There is a lot of good advice here, but if it's your first cam, maybe choose a little more modest path, and cams are not permanent either. You can always put a different one in later at your next spring maintenance point and would likely not cost as much. The permanent excitement factor will offset any drivability concerns. Frankly, after driving this first cammed car of mine, I feel I could handle bigger without any issue and you probably could handle that one. See if someone near you has a cammed car to test.
01-11-2016, 09:15 PM | #25 | |
Drives: ‘13 1LE Join Date: Jul 2013
Ultimately, a DD type, particularly urban, must ask themselves right into the mirror, "do I risk getting sick and tired of my extroverted cam, and wanting to go smaller after a couple of years, or do I wish it had been more extroverted to begin with?" |
01-11-2016, 09:30 PM | #26 |
Drives: A wrench Join Date: Jan 2010
01-11-2016, 09:40 PM | #27 |
Drives: A wrench .... I like that!
-Don
747 RWHP 794 RWTQ
01-12-2016, 08:47 AM | #28 |
can't wait......
