07-09-2015, 04:05 PM | #15 | |
Track > 1/4 Mile
07-09-2015, 04:37 PM | #16 |
Drives: Several in a big garage Join Date: Jan 2014
Welcome to the joys of trying to track a supercharged car. The issues you're experiencing are exactly why I sold my ZL1. I recently bought a z/28 to replace it, and have yet to have any issues with heat dissipation. Good luck!
07-09-2015, 05:00 PM | #17 | |
Drives: 2013 ZL1 M6 Join Date: Jan 2014
I'm considering trading in my ZL1 for 2013-2015 Viper. Just because I can. I happen to really like the ZL1, but my wife hates it.
Corvette Z06/Z07/M7 (2016) Late Model Racecraft Intercooler reservoir and 160* Thermostat.
Sold- 2013 Camaro ZL1 M6 (Black on Black), Detroit Speed Sway bars, DOT 4 Brake Fluid, separate clutch master reservoir, Moroso Catch Can. 2.11 at Thunderhill 100* ambient. Ron Davis Radiator and AFCO Heat Exchanger installed after track day, Roto-Fab CAI. Sold- 2001 Mustang Cobra -Griggs GR40,M5, Torsen T2-R, 4.10, 14" Brembo fronts, high 1:40s at Laguna Seca |
07-10-2015, 01:00 AM | #18 |
Turned out to be a cooler cloudy day so no issues. The DIC said 270* but the gauge for my oil temp never got pinned although it did at one point go about 3-4 needle widths from pinning hot.
As far as the "dreded heat soak" I've yet to have that happen to me and I was running at 7/10's most of the day today at the Ridge. The only changes I've made are; Bottle of Water Wetter in the cooling system CAI DOT 4 brake fluid flush Hawks pads all the way around All fluids in my car were changed before track day Thats it and it runs hard and fast all day. Another successful track day done. My 2nd this year, and possibly 2 more to go. A number of people have told me about the issues I will have but so far none have happened. I think because I'm in the Pacific Northwest its a little easiermon the cars and I also don't run mine flat out. Imuin it for fun and have illusions of being some great race driver. Same reason I don't run mine flat out, i need my car to get me home and still work as a DD. Just my 2 cents. But I will look at additional oil cooling just for the comfort factor as I add more HP.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
07-18-2015, 11:22 AM | #19 | |
Attached is my second oil change. I had my first oil change at about 1,500 miles and did not have it analyzed. The second oil change was at about 8,200 miles (6,700 miles on the oil) with two track days. I also had the TBN analysis completed and Blackstone said I can extend my oil interval to 8,000 miles. Also my aluminum are iron numbers are higher than yours and they attribute it too break in.
07-18-2015, 06:00 PM | #20 |
Drives: 2015 LFX Auto Join Date: Apr 2015
Have you logged it when running to see what is happening with your timing when it overheats. Seeing the corvette C7's are pulling timing due to detonation from the oil ingestion, and they are seeing timing pulled to the point it is causing the overheating. Post up some logs if you have HP Tuners for us to see.
07-19-2015, 05:59 AM | #21 |
Drives: '16 C7 Z51 Join Date: May 2012
I can't believe I missed this post; I must have ignored it seeing ZL1 in title : )) I honestly did not have too big of an issue on cooling the SS, but I've had huge issues with cooling my supercharged Miata, which taught me a lot, and yes, I fixed it! We always need to think of cooling as the whole system.
Air flow:
Thermostat / Coolant:
Oil grade:
Oil temp gauge:
Additional (air-to) oil cooler: You are right, the single biggest thing you can do to drop your coolant temps is to let it free of cooling the oil. That said, cooling oil is a very hard task, and will cost you $1000 to properly do so. My recommendation:
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
07-19-2015, 10:45 AM | #22 |
Drives: 14 1LE Join Date: Mar 2013
Lots of good info there, X25. I fully agree.
LMS Engineering
07-19-2015, 10:55 AM | #23 |
07-19-2015, 05:15 PM | #24 |
Drives: pleather and Chiclets Join Date: Mar 2012
I have run in 118 ambient with the black top over 150. I am no supercharged. I run distilled water and water wetter or amsoil water boost (sorry forgot exact name). The ones with anti corrosion in it. I seperated my Trans and oil cooling off to seperate rads. It makes a word of difference. Only my brakes worry me with heat anymore x25 listed out a really good bullet point presentation... Should be a stick post!
07-20-2015, 05:28 AM | #25 |
Thanks guys, I'm glad you guys didn't see my line of thinking ridiculous. It's a tough task, and at some point, how good your solution is will depend on how much you think it's worth investing.
07-23-2015, 01:44 AM | #26 | |
Sold- 2013 Camaro ZL1 M6 (Black on Black), Detroit Speed Sway bars, DOT 4 Brake Fluid, separate clutch master reservoir, Moroso Catch Can. 2.11 at Thunderhill 100* ambient. Ron Davis Radiator and AFCO Heat Exchanger installed after track day, Roto-Fab CAI. Sold- 2001 Mustang Cobra -Griggs GR40,M5, Torsen T2-R, 4.10, 14" Brembo fronts, high 1:40s at Laguna Seca Last edited by LagunaSecaZL1; 07-23-2015 at 09:25 AM. |
07-23-2015, 02:12 AM | #27 |
Drives: 2010 SS RS Join Date: Apr 2009
I'm testing the lingenfelter 174 stat on the street for the last 2 days. No auto-x or hard racing yet. So far, it is a little better than OE and much better than the (2) other 180 stats, but not as cool as 160. The 160/174/180 are motorad/Murray designs. The other 180 is a Napa(worst so far) and my OE ac delco 186(3rd place). I will run it a couple more days but will probably put back the 160. With the dewitt dual core radiator and OE water pump, coolant flow based on rpm plays a huge role with the different designs and temperature openings. Ac on and off. I'll post side by side pics of the 5 stats later. Would be interesting to see the stats used with an OE radiator.
07-23-2015, 02:51 AM | #28 | |
