11-05-2014, 03:35 PM | #15 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
Glad to hear Im not the only one... Thanks for the input everyone, and I apologize for the dual posting... (thought this one was deleted) - dont have too much faith in taking it to the dealership though...
11-05-2014, 07:51 PM | #16 |
Drives: 2014 v6 Join Date: Nov 2013
Add me into the list as well.
11-05-2014, 10:49 PM | #17 |
Drives: 11 Camaro V6 RS, 03 BMW Z4 Join Date: Oct 2013
I also don't want to take it to the dealership as my car is overseas. It took over 2 weeks to replace and paint my rear bumper. I have no idea how long it would take them to replace the whole assembly.
11-06-2014, 04:45 AM | #18 |
Drives: 2012 2 SS/RS Join Date: Oct 2014
11-24-2014, 07:52 PM | #19 |
Drives: 2011 summit white 1LT RS Join Date: Jul 2014
hey, ive been having this problem too after i installed my winter rims. usually occurs when i do little turns. idk if its the winter tires' rubber rubbing against the ground or its the steering wheel. but i really think its the steering wheel. anyone knows what this is or how to fix?
12-01-2014, 05:07 AM | #20 | |
2012 45th RS/SS
ADM Perfomance intake, ADM tuned, Stainless Works headers/no cats, 3" magnaflow comp exhaust, 160º thermostat, Nitto NT05R's, 387rwhp/396tq 95 Kenworth W900L powered by CAT 13 spd |
10-11-2016, 06:36 AM | #21 |
Drives: 2014 Camaro 2LT Deep Magenta Join Date: Apr 2015
I have this same issue, took it to the dealer 3 times saying they lubed up moving parts... do I ask for them to replace under warranty? Same description as you guys...
02-15-2018, 10:24 PM | #22 |
Drives: 12 Camaro SS Join Date: Mar 2012
Any new revelations on this? My 2012 SS started doing it a few months ago. Sounds like it's under the plastic at the top of the steering column.
2012 Camaro VR A6 SS
2004 Pontiac GTO PBM A4 |
10-27-2023, 05:18 PM | #23 |
Drives: 2014 Chevrolet Camaro 2LS Join Date: Apr 2020
I’m just about to hit 35k miles on my 2014. It’s got the squeaky steering wheel turning both ways now and it’s getting louder. Sounds like a squeaky wood door on an old farm house. Hoping it won’t burn a hole in my pocket 🤞
10-27-2023, 07:19 PM | #24 |
Honestly,I got under the steering column with a big towel and coated it well with WD40. Under the dash and in the engine compartment where it comes through the firewall. Seems to have helped a lot.
10-28-2023, 10:31 AM | #25 |
Be careful with this stuff as it contains a lot of solvent and will wash away any lubricate, grease or oil anywhere! Back in the day when I worked at a machine shop as a tool& die apprentice we had a large stainless steel table we used for measuring and marking. On Friday's we would clean the table, coat it with a very thin layer of light oil so it would stay clean for Monday's use when we got back. One Friday one of the guys used the WD40 instead of the oil, and when we got back on Monday the ENTIRE table was coated with a film of rust!! The WD40 solvent had taken all the oil film off the table!! It was dry!! I would suggest for the squeak use a quality silicone spray lube instead. That way it will stay there where you spray it. Works wonders on plastic, rubber AND even door locks and latches. And no smell!!
