Vararam
Old 12-09-2014, 05:31 PM   #15
AG1LE
AG1LE's Avatar
Drives: '14 1LE
After seeing the Z06 I wish someone would make a similar wicker bill for the 1LE - wraps around the sides of the spoiler and is adjustable in the middle
AG1LE is offline   Reply With Quote
Old 12-09-2014, 07:38 PM   #16
Aero_Sport_Concepts
aerosportconcepts@gmail
Aero_Sport_Concepts's Avatar
Drives: '15 1SS-RS/1LE (RRM)
Hold tight brotha. Waiting on the material to show up. But its coming , i promise .
Aero_Sport_Concepts is offline   Reply With Quote
Old 12-09-2014, 09:57 PM   #17
toehead93
Drives: 2014 2SS/1LE
email me details when you can please. jtjoet @ yahoo .com
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 12-10-2014, 08:04 AM   #18
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 Chevy & 2021 1SS/1LE manual
i just realized that i was posting SS spoiler stuff in 1LE thread. sry bout that guys. i searched spoiler and found this thread. i rode in a 1LE last year. its a good car.
JOHNSONROD is offline   Reply With Quote
Old 12-10-2014, 10:54 PM   #19
Chris1SS1LE
Chris1SS1LE's Avatar
Drives: 2014 Camaro Red Hot 1LE NPP Recaro
Originally Posted by Bhobbs View Post
If you track your car a lot, I would think twice before adding the wickerbill. The 1LE is set up as is to reduce understeer. Al O said adding more downforce to the rear end of the car would cause understeer which is why the 1LE has the spoiler it does.
This is what I was worried about too, it would like adding a 305 rear tire. It would cause the front to push and understeer more. Now if you added the front splitter and proper one. Where it is attached to the frame, so when the air pulls it down, it pulls the chassis and not stretching the plastic bumper cover. I had a real Cobra R splitter on my cobra and pretty exterior spoiler attached to the bumper cover, but it also came with a piece that fitted the entire bottom of the external splitter and had two aluminum towers that mounted to the chassis that held the steel bumper on behind the front plastic fascia. It was a honeycone core wrapped in fiberglass.
The body mounted splitters will direct air, but any true down force will not really happen. The best way to see this is watch built drag cars at the top end who remove the steel bumpers behind the covers, they fronts implode at speed creating a parachute more then aerodynamics. Then when they slow down the bumper goes back to its shape. Hence why a buddy sells lightweight bumper replacements.
I think the cool factor is there, but again it creates drag too, So it can slow your car down a little.
Chris1SS1LE is offline   Reply With Quote
Old 12-10-2014, 11:44 PM   #20
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
It makes 150lbs of down force at top speed. Would be great for the esses at Watkins or VIR. Under a 100mph and I bet it is near impossible to notice. Having an extra 10 gallons of gas in the tank for a session is 70lbs right there. I consider it another adjustable tuning device. It has height adjustments, and can also be removed based on the track you are at. I don't disagree that off setting it with a bigger splitter is advised, but that is near impossible to adjust at the track.
tw78911sc is offline   Reply With Quote
Old 12-11-2014, 09:47 AM   #21
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
Well the 13 1LE uses the same spoiler as a 2010-2012 and the 1LE IS an SS as I understand it, it's just painted satin black. My understanding is the only difference between a standard SS and 1LE on these years in the rear are the wider rear tires and 285 rubber. If I am incorrect, please do let me know.
Let me know once you've tested it. I'm curious to know which ones work best on the 2013 1LE since that is what I'm having... You 14-15 guys can just buy the Z/28 wicker bill/splitter and be done with it since GM did all of the engineering for you (lucky!)
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
Old 12-12-2014, 12:04 AM   #22
Chris1SS1LE
The 14-15 1LE spoiler is the ZL1 Spoiler, I don't see how its different besides the wrap.
Old 12-12-2014, 09:32 AM   #23
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Correct, the 14-15 1LE spoiler is the ZL1 spoiler (thicker than the SS spoiler), but it is painted black (not a wrap)
Old 12-12-2014, 10:09 AM   #24
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I am going to let some of the others go into details, but the suspension in the rear is different on the 1LE to the SS as well.
gajagfan is offline   Reply With Quote
Old 12-12-2014, 10:51 AM   #25
markgws6
markgws6's Avatar
Yes, but I was referring to the aero, as this thread pertains to it...
(1 of 43)
Old 12-12-2014, 11:51 AM   #26
gajagfan
gajagfan's Avatar
Gottcha, and I thought it had expanded into a discussion of oversteer / understeer, which is also effected by the suspension, and since tires (which you mention) are generally not considered part of the aero package, I assumed you were on the same page as me. My bad. I am interested to see if they two spoilers are the same.
Old 11-25-2015, 12:55 PM   #27
JC1LE
JC1LE's Avatar
Drives: 2014 2SS (OLD) / New 2015 1LE
bump
The Juan from Norcal Camaros
2014 2SS RIP - 2015 1LE on the way!
JC1LE is offline   Reply With Quote
Old 11-25-2015, 01:23 PM   #28
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Contact Kurt from Aero Sport Concepts(C5 vendor) he'll hook you guys up.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
