TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 08-14-2014, 09:06 PM   #15
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Drives: My wife crazy!
Went to the strip tonight. Stock Tires
#378
M3hta1 is offline   Reply With Quote
Old 08-14-2014, 09:42 PM   #16
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
#378
I'd say something is way off, that mph is way low for the power you made. That is a mph for a stock car.
BFASTNOTLAST is offline   Reply With Quote
Old 08-14-2014, 10:29 PM   #17
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Yeah keep track of where you are shifting, might be low?
I run 89/90 in the 1/8 in my auto shifting at 6000.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 08-14-2014, 11:20 PM   #18
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
John you shift at 6000? Seems low, I shifted mine at 6300-6400 stock cam, maybe I was over reving?
Ya I agree, MPH is low. Work on that tune!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 08-15-2014, 10:17 AM   #19
07-SRT
07-SRT's Avatar
Drives: 2015 Camaro SS
what was the DA ? Something doesn't seem right... Your 1/8th mile time would equate to a high 12- 13 flat et... Even on stock tires (2.0 60')- with the power your making, you should be capable of mid to low 12's..... JMO
2015 Camaro 2SS
Cam/Heads/FBO 498/447 SAE
07-SRT is offline   Reply With Quote
Old 08-15-2014, 10:23 AM   #20
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Yeah I need to definitely work on my shift points. Also my tune seems a little out of wack. Engine power cut at launch rpm goes down to 1500rpm then catches back up after a fraction of a second.
I need to work on my tree, launch, and shifting.
Old 08-15-2014, 12:39 PM   #21
Pro Stock John
Writer
Mike you are LS3, has different cam. Stock L99 cam is done at an lower rpm.
OP if you make peak HP at say 6500 you would want to start by shifting around there. I'm thinking you should be going for like 94MPH in the 1/9th... no?
PROJECT HEAVY CHEVY
Old 08-15-2014, 01:27 PM   #22
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Yes you are right. From the dyno between 6000-6500 is my powerband. So should be shifting at 6500 right before limiter?
I may need a light to help me with this cause the way my wheel is it is kind of hard to see the tac. Also switched to the tac / mph on the HUD but in all honesty it isn't big enough....
I just have to keep practicing.
Old 08-15-2014, 01:29 PM   #23
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Can you explain DA? And how to calculate it?
Old 08-15-2014, 02:38 PM   #24
07-SRT
07-SRT's Avatar
Density altitude...it puts everyone on a level playing field and what your car is capable of at sea level under certain conditions, just like dyno correction factors do...here is a calculator below.
http://www.dragtimes.com/da-density-...e=Calculate+DA
2015 Camaro 2SS
Old 08-15-2014, 03:50 PM   #25
Pro Stock John
Writer
Maybe adjust the column to see better?
PROJECT HEAVY CHEVY
Old 08-15-2014, 06:26 PM   #26
BFASTNOTLAST
Drives: 2012 SS LS3
Soon enough you will be able to teach yourself when to shift by the sound, with enough practice over the years you will know when you messed it up. I very rarely look at the tach anymore. Once in a blue moon I will bounce off the limiter in 1st but its so short with the gear I have you must be ready to row the shifter.
You will get it, keep at it.
Old 08-15-2014, 06:39 PM   #27
BFASTNOTLAST
Drives: 2012 SS LS3
BTW, I switched to a smaller tire today (275-35-20) to get the same result of adding more gear. I now mathematically have a 4.10 or so final drive. Stick cars need a 4.10 IMO!!! The tire is over an inch smaller. Don't let the internet jockeys fool you saying 4.10's are too much, not true at all. However, I would get a GM 3.91 gear set and do the smaller tire, to many horror stories of the 4.10 ring and pinion not lasting. I have yet to hear of a 3.91 breaking. Than again there is always a first.
Old 08-15-2014, 10:11 PM   #28
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Thanks for the info BFASTNOTLAST. I plan to keep at it.
