07-08-2014, 09:28 AM | #15 | |
Keeping heat out of the intake stream is part of how they achieve max performance, on the dyno, street and track. Ted.
www.jannettyracing.com
07-09-2014, 08:41 AM | #16 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
So raising these numbers 10% will allow 10% more power to pass thru?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
07-09-2014, 08:57 AM | #17 |
Geek
It is just torque limited by RPM. I did the same as Iam Broke and set everything to the maximum. If you want to limit torque... lift your foot.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
07-09-2014, 09:14 AM | #18 |
can u give me an example how u maximized the numbers, the tuning gets me confused as some scales we make the numbers smaller to get more power and some the opposite.
07-09-2014, 09:33 AM | #19 |
Forgot to ask, was it a noticeable change?
07-09-2014, 09:59 AM | #20 | |
Geek
07-09-2014, 10:31 AM | #21 |
So raising the numbers increases the power to pass thru based off of your response, correct?
thanks for the info!!
07-09-2014, 10:46 AM | #22 |
Geek
Yes. The numbers in the cells are where TQ management will kick in. If you set them all to 6042 it can never get there. That is a pretty standard practice. Set the cell to something out of range to disable some functionality.
07-09-2014, 10:49 AM | #23 |
Great, Thanks!!
07-09-2014, 11:07 AM | #24 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I didn't see any information about the track conditions (DA). I know that running a car down the strip in Texas at this time of year can be a heart breaker.
Especially at some of the tracks that have a little bit of elevation to go with the heat. Well I answered my own question. Conditions were not all that bad that day, but the DA was +2194 ft. based on DragTimes.com His corrected time was 12.7 @ 112.78 mph. So he's a little off the pace for his mods. |
07-09-2014, 11:49 AM | #25 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
IneedAZ - I have read on other forums that setting the tq #'s to max causes issues in some ECM's. Mine is the same as Hemp's with no issues but if you find the throttle closing on you up top before the rev limiter, back it off to 6000 and you will have no issues. You'll never see 6000 ft/lb anyway.
Another 1 of 371 '12 T3 LS3 M6's built.
07-09-2014, 11:55 AM | #26 |
PHAT B33
The tables highlighted in green are modified compared to a stock file. The ones that are not open in this pic can be all set to 6000.
07-09-2014, 12:36 PM | #27 |
I figure since i already changed the TQ management for the tranny i should try the engine. I felt a difference just doing the tranny, so i hope to feel a difference with these as well.
07-09-2014, 01:05 PM | #28 |
Geek
Interesting. I had not seen or heard of that. Good to know.
