12-17-2013, 01:50 PM | #15 | |
Drives: Camaro Join Date: Apr 2012
It's set at a predetermined weight. Too light and it won't go off. You can test it in your Camaro. Look at the light on the mirror. It will tell you if it is active or not. |
12-17-2013, 01:54 PM | #16 | ||
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
The Bird is the word! |
12-17-2013, 05:16 PM | #17 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
Could have just had a second "Track Key" disabling the airbags, hate to do it...
http://www.fordracingpartsdirect.com/category_s/523.htm
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
12-17-2013, 05:34 PM | #18 | |
Drives: 2011 Camaro 2SS/RS Join Date: Dec 2010
Also the Ford Track Key, while providing many changes that one would want for the track the one thing that it doesn't do is disable the air bags. |
12-17-2013, 06:22 PM | #19 |
They could just wait until it kills someone on the track and then get sued I suppose.
http://editorial.autos.msn.com/blogs...4-cc436b8f1706 Coworkers wife now has to take seizure medication and lost he license after the side airbag in their Nissan bruised her brain. I can live without them thanks.
05-24-2015, 09:16 PM | #20 |
Ain't Scared Racing
Drives: 2015 Summit White Camaro Z28 Join Date: Jun 2012
It can even happen to an RS on the track.
05-24-2015, 09:35 PM | #21 |
Drives: 2012 camaro Join Date: Feb 2012
2 yr old thread dude
05-24-2015, 10:35 PM | #22 |
Panama-Gulf War Vet
Drives: '11 SW 1LT/RS 6M Join Date: Apr 2011
So in my F-150, you could use the ig key to turn the passenger airbag on and off. This was for car seats and cardiac pts. and pregnant ladies. I think you are instructed not to drive after o.h.s. That was a 2003.
Troy |
05-25-2015, 07:05 PM | #23 |
Drives: 2011 IOM 2SS/RS M6 Convertible Join Date: Feb 2014
That system was replaced with the automatic passenger sensing system in later years, I don't think anything has manual airbag switches anymore.
05-25-2015, 07:32 PM | #24 |
Drives: 2015 BVM 1SS/1LE Join Date: Aug 2010
I don't believe they can disable all the airbags, but there are vehicles that have switches to disable some of them. My other vehicle is a 2013 Toyota Tacoma TRD Off Road 4x4 Pickup. It has an airbag disable button right on the dash. I read the owner's manual, and it disables the side curtain airbags only. It is supposedly to be used when driving the truck off road, so that a steep approach angle on a hill where one side of the truck is up much higher than the other doesn't trigger a sensor, thinking the truck is rolling and activate them by accident.
My off roading is usually not anything that severe or extreme that it should be a concern though. I've seen online where guys use these trucks to go dune jumping, rock crawling and all sorts of extreme off road uses where I guess that little button is a real necessity. My off roading activities are a bit more tame by comparison. Through a meadow at a farm and up a dirt road to cut firewood and load up the truck, or up old logging roads when I go hunting. That's about it, the truck doubles as my daily driver when home and traveling to work or out to the hardware store for supplies, so I really don't do anything too crazy with it. Using that as an example, I don't see why the Camaro couldn't have a similar button intended for track use that just disabled the side curtain ones so they don't deploy if the vehicle gets sideways a bit. I dunno, I'm sure there is some reason why they don't. |
