Old 03-21-2013, 06:11 PM   #15
SC2150
Drives: 2012 Camaro RS, RX supercharged
Originally Posted by litle88 View Post
Tracy don't mind him, he's got a BWM now! Thanks for the info always a pleasure reading your stuff. Now how would you go about me? You've seen my setup and catch can is vented. I'm SD and the Driverside is capped. Should I vent the D/S (what is the part to do it with) and plug the catchcan back to the intake? Ps I'm a stroker with hellfire rings and built a lil on the loose side.
"Talk to me Goose" I mean Tracy. Lol
LOL! Your SD tuned so no need to control the clean side air entering. I would put a breather (an open non valved one) on the opposite valve cover you have the can evacuating from and then use the IM vacuum barb to evacuate (as long as your NA) that way at all running except WOT (when there is no measurable vac at the barb) your always evacuating and your can will trap any oil from ingesting. If you have more crankcase pressure at WOT than will run through the dirty side it will vent out the breather and all is good (assuming your off road only use as far as emmissions).
Originally Posted by SSDan View Post
Tracy, in earlier posts you have mentioned the Mike Norris can as a good one. That is what I am running so I am curious - have you changed your mind? I know you can't test and list all the catch cans out there nor do I expect you to. So, I ask only because you have mentioned the Norris can in the past.
Thanks for helping us out on this always heated topic.
Yes, the MN can (or CCA and several other brands on it) works well with most mild builds and only allows a moderate amount of pull through. It came in just under the Elite/AMW and thats only because of the coalescing chamber size so small and the outlet barb is only app 1" from where the droplets are dripping from the coalescing chamber so some get pulled out. Still an excellent can.
SC2150 is offline   Reply With Quote
Old 03-21-2013, 06:22 PM   #16
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Thanks Tracy, and cap the Valley cover tube? Or "T" it to the passenger side valvecover leading to the catch can?
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 03-21-2013, 06:23 PM   #17
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Sorry Apex! Didn't mean to high jack one more response and ill shift it back to you guys. Lol
Old 03-21-2013, 06:24 PM   #18
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ROFL guess people missed the joking part.
mikeSS is offline   Reply With Quote
Old 03-21-2013, 07:24 PM   #19
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Go away BMW boy "your drunk" lol
Old 03-21-2013, 07:53 PM   #20
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by mikeyg36 View Post
Great job Chase! Keep these threads coming
Thanks. Seems like lately some have forgotten what a technical forum is for and decided to unleash their sales staff instead. That is not how we operate. We will focus on providing technical material and being an asset to the community.
No apologies need. That is what this thread is about.
I knew better.
Apex Motorsports is offline   Reply With Quote
Old 03-22-2013, 07:07 AM   #21
motorhead2011
motorhead2011's Avatar
Drives: 2011 IPC,2014 GT500
Originally Posted by Apex Chase View Post
Modern engines feature a variety of emission control devices and systems to reduce the toxic gases released into the atmosphere. One of these is called the Positive Crankcase Ventilation (PCV) system. During the combustion process a small amount of gases leak or "blow-by" the piston rings and create a positive pressure in the crankcase. The PCV system vents these gases along with oil mist from the crankcase and routes it back into the intake manifold so it can be burned off. The problem is, over time the excess oil vapor collects along the inside of the intake tract and forms a "gunk". This can lead to a variety of issues including carbon build up, retarded timing, detonation, and power loss.
Carbon build up on intake valves
A "catch can" is an aftermarket device that will condense and collect the oil vapor before it has a chance to reach the intake system. As the gases and oil vapor enter the can they typically pass through a screening mechanism that gives the oil vapor something to adhere to. As the droplets form they drop harmlessly into the bottom of the reservoir so that they can later be drained. The other gases are allowed to pass through so that they can be burned of as intended.
Fluid captured in catch can after 800 miles
When it comes to selecting a catch can you will get what you pay for. Cheap catch cans (less than $100) are plentiful but they are often little more than an empty can with two ports. These will capture a small amount of fluid but the vast majority passes straight through and ends up where you don't want it. Be sure that the can is designed with an effective internal baffling system to pull the oil vapor out of suspension. RX Performance and Elite Engineering catch cans are both great options for V6 and SS Camaro owners. As always, if you have questions regarding this or any topic the crew at Apex Motorsports is more than happy to answer them.
A pic of mine i got from you Chase. Great write up.
motorhead2011 is offline   Reply With Quote
Old 03-22-2013, 07:34 AM   #22
StreetSS
Drives: 2011 Camaro SS
I installed an Rx can recently on a car w/3,000 miles. Is there anything I need to do check for and clean out any build up of oil? Also, if I find "mythical" oil, is there a special procedure to clean it out?
StreetSS is offline   Reply With Quote
Old 03-22-2013, 01:20 PM   #23
SPCBA
Drives: pleather and Chiclets
i had a catch can which works and a breather for valve cover and the clean side capped off....i went road racing and the pressure built up in my crankcase and blew my rear main seal. i now run the same catch can with the 1LE seperator that catchs the clean side and lets it drain back in while being able to relieve pressure in crank.
i know the rx catch can works beautifully. and the 1LE sperator is oily where i didnt put it so i know that it is doing some collecting and letting it drain back in.
SPCBA is offline   Reply With Quote
Old 03-22-2013, 02:06 PM   #24
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I remember BA, so that worked for you hu?
Thanks for the tip bud. I appreciate that!
Old 03-22-2013, 02:11 PM   #25
Oldag
Drives: 2013 2SS Convertible, LS3
Originally Posted by SC2150 View Post
So deleting the PCV system, or just running breathers, etc. will releive the crankcase pressure from the blow-by....but unless your changing oil every few times the engine is run, the wear is accelerated substantially.
Have to disagree here. Breather caps were all that was available until around 1970 or so (give or take a few years). PCV systems have not been on cars since day one. The statement of substantially accelerated wear is not substantiated.
Letting the fumes go to atmosphere will not accelerate wear as opposed to leaving the PCV system in place. And as has been pointed out, not recycling those fumes into the intake has advantages.
The average car will not see a benefit between pulling a mild vacuum and venting to atmosphere.
Will disconnecting the PCV cause error codes? I do not know. This could be a complication.
Oldag is offline   Reply With Quote
Old 03-22-2013, 04:26 PM   #26
Apex Motorsports
Thanks! I dig the garage decor.
Old 03-22-2013, 04:30 PM   #27
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Ok I changed it today since the weather was kinda nice. So Tracy is this better?
Here is the drivers side valve cover with just a breather and no valves.
Old 03-22-2013, 05:36 PM   #28
SPCBA
worked beautifully. already been on a road course with this setup. everything is clean where it should be and pressure is able to be released. i dont have the quarter of water bottle gunk stuck in the catch can when doing oil changes...more like a couple of big spoon fulls. regardless i am happy it isnt being injested and dumped in my intake and valvetrain. think my break in philosphy of running it hard with magnetic drain plug and filter sleeve with oil changes every 500 may or may not have helped with that.
apex catch can, apex motorsports, catch can, elite engineering catch can, rx catch can
