View Poll Results: Do you have 2nd Gear Grind, what's your shifter? | |||
OEM | 75 | 28.85% | |
OEM Hurst | 76 | 29.23% | |
Aftermarket | 49 | 18.85% | |
No | 60 | 23.08% | |
Voters: 260. You may not vote on this poll |
Thread Tools |
02-16-2012, 09:01 AM | #15 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Mine was doing it bad at high RPM, I changed the break fluid with freash dot4 and put royal P syncro mesh in the trans... My trans works awsome now, I havent had problem since the day I did it.
10.91 at 122 H/C stock block N/A
02-16-2012, 09:34 AM | #16 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
Mine ground with stock and continues with aftermarket . Mostly when trans is cold. When oil is hot it doesnt do as often
PIPE
02-16-2012, 02:02 PM | #17 |
Drives: 2012 ZL1 Join Date: Jun 2008
Oem and mgw
02-16-2012, 02:11 PM | #18 |
Little Rock
Drives: 2011 2SS/RS IOM M6 & '02 Silverado Join Date: Jan 2011
Oem and MGM both grind 2nd every now and then
2011 IOM 2SS/RS Defenderworx black billet bowties & gas door Roto-fab CAI MGW short throw shifter |
02-16-2012, 07:55 PM | #19 |
Yes, aftermarket Hurst. Only when shifting rapidly, and only into second. Did it with the OEM shifter as well.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
02-16-2012, 08:39 PM | #20 |
Royal P guys, trust me it made a big difference.
02-16-2012, 08:58 PM | #21 |
Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
OEM Hurst and no grind
1968 Camaro Convertible LS1, T56
02-17-2012, 12:44 AM | #22 |
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28 Join Date: May 2009
Mine only grinds when the fluid is cold. Using the MGW shifter. 34,000 miles. Plan to install RP fluid to see if that helps.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold 1968 Camaro - Sold 2019 Corvette Grand Sport |
02-17-2012, 03:12 AM | #23 |
Drives: 2011 1SS/RS , 1966 GTO Join Date: Jul 2011
Yes, OEM Hurst
A machine for shrinking time and distance.
02-17-2012, 03:28 AM | #24 |
Drives: IOM 1SS w/factory Hurst Join Date: Jan 2011
Its kinda odd. I had the OEM Hurst and had grind under hard accel and even just poking around a few times. Now that I have the aftermarket Hurst I've only had it happen once and my tranny seems to be shifting smoother.. I don't know if it just the more connected feeel that makes it feel smoother or what.
"Success is following the pattern of life one enjoys most."
Stainless works Catback with Flowmaster Single Chamber Mufflers, Vararam, Factory Hurst, SLP SS emblems, SLP Skip Shift |
02-17-2012, 12:11 PM | #25 |
Drives: A Gift From My Wife Join Date: Apr 2009
Once my tranny is up to temp I can redline shift to 1-2 without it grinding. -Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping. 08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery). 08/16/2011 - (5000) Vehicle has been delivered to dealer. 08/19/2011 - In my possession. |
02-17-2012, 12:19 PM | #26 |
Drives: 2012 2SS/RS IOM Join Date: Nov 2011
Yes, OEM hurst. My grind is very minimal. I find that I "grind" more when I put weight on the stick towards the driver side. If I allow the stick to drift downward and a bit to the right before I try to enter second gear, I seem to avoid the slight grind.
It's completely counter intuitive, hard to speed shift, and should be unnecessary..... but this is what I must do apparently... |
02-17-2012, 05:53 PM | #27 |
Yep, OEM Hurst here.
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars] |
02-17-2012, 10:54 PM | #28 |
Same here
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Rear End Gears 101 | danhr | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 92 | 06-02-2021 04:17 AM |
Another TR6060 with 2nd gear grind | DRG BSTN SQUIRREL | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 9 | 12-16-2011 03:41 PM |
2011 2SS/RS Problems: Engine Squealing, Brake Squealing, 1,2 Gear Grind. Please Help. | qniknam | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 4 | 10-30-2011 10:36 AM |
2nd gear and Reverse of Fiero grind/won't go into gears. Any takers? | Arachnyd | General Automotive + Other Cars Discussion | 0 | 03-20-2011 01:05 PM |
3rd gear grind ? Only 3000km | Inferno Orange SS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 22 | 12-28-2010 03:25 PM |
