Go Back   CAMARO6 > Members Area > Site Related Announcements / Suggestions / Feedback / Questions
Old 01-29-2012, 06:48 AM   #15
Uneducated Guess
'12 ZL1 #742
Uneducated Guess's Avatar
Drives: his wife crazy
an easier way is to copy and paste the URL from the address bar. This way you don't have to use the [ u2b ][ /u2b ]. It has to be from the address bar though because if you use the embedded link they give you, it will show up as a hyperlink.
Uneducated Guess is offline   Reply With Quote
Old 01-31-2012, 08:21 PM   #16
TCAT
TCAT's Avatar
Drives: Has Wheels
How do you embed a video that is from Photobucket (if that's even possible)???
TCAT is offline   Reply With Quote
Old 04-09-2013, 03:34 PM   #17
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
[U2b]
[u2b]
Nightmare2012 is offline   Reply With Quote
Old 04-09-2013, 03:37 PM   #18
Nightmare2012
come find out;)
http://m.youtube.com/?reload=9&rdm=0...Dmv-verizon-us
Old 05-12-2013, 07:44 PM   #19
Originally Posted by Nightmare2012 View Post
[U2b]
[u2b]
If the URL has HTTPS you must remove the "S"
Also... if you are posting from a mobil phone you must take the "M" out of the address.
Old 07-16-2013, 08:50 AM   #20
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
Anyway to do a FaceBook Video?
Example
http://www.facebook.com/photo.php?v=...19998386226195
or
http://www.facebook.com/video/embed?...56199787817013
IN the PHPBB forum for SCC i had to make a new code for this
<object width="640" height="360" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/video/embed?video_id={NUMBER}" /><embed src="https://www.facebook.com/video/embed?video_id={NUMBER}" allowfullscreen="true" width="640" height="360"></embed></object>
KalCorp is offline   Reply With Quote
Old 09-03-2013, 02:39 PM   #21
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
http://youtu.be/OnJ7u1vX8M4
My build thread.click the pic. COTW 10/24/11
Chris-10 is offline   Reply With Quote
Old 09-03-2013, 02:52 PM   #22
Chris-10
Chris-10's Avatar
http://youtu.be/OnJ7u1vX8M4&fs=1">http://youtu.be/OnJ7u1vX8M4&fs=1" type="application/x-shockwave-flash" width="855" height="505">
Old 09-03-2013, 02:59 PM   #23
Chris-10
Chris-10's Avatar
I'm too stupid to figure it out....
Old 09-04-2013, 12:01 AM   #24
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
don't know how to do the fb one, yet...maybe copy paste the url into the image tag above or the hyperlink tab?
TAG UR IT is offline   Reply With Quote
Old 09-04-2013, 12:32 AM   #25
alex70olds
alex70olds's Avatar
Drives: 2012 ZL1 #141
Chris, press the quote button on this post. It should look like what is inside the quote tags. ignore the
PHP Code:
[QUOTE=alex70olds;6976851][/QUOTE
In other words should look like
PHP Code:
[u2b]OnJ7u1vX8M4&feature=youtu.be[/u2b
alex70olds is offline   Reply With Quote
Old 09-04-2013, 01:09 AM   #26
alex70olds
alex70olds's Avatar
Example
or
Before about April of this year you could post it using [video] tags, as long as it was set to "public" Since then FB changed, so adjustments have to be made by an Admin in the style manager. You have to find -
Code:
<object class="restrain" type="application/x-shockwave-flash" width="576" height="432" data="//www.facebook.com/v/{vb:raw code}">
<param name="movie" value="//www.facebook.com/v/{vb:raw code}" />
<param name="wmode" value="{vb:raw wmode}" />
<!--[if IE 6]>
<embed width="576" height="432" type="application/x-shockwave-flash" src="//www.facebook.com/v/{vb:raw code}" />
<![endif]--></object>
Then replace with -
Code:
<iframe src="https://www.facebook.com/video/embed?video_id={vb:raw code}" width="720" height="450" frameborder="0"></iframe>
Width and height can be adjusted to whatever the admin prefers. After this is done a simple hyperlink, or even youtube tags will successfully embed a facebook video. You could also do it in html, if enabled, but this exposes serious security issues.
This site is running version 3.8.7 which is quite outdated. Current version is 5.0 and I believe they have this issue resolved.
Old 10-02-2013, 06:49 PM   #27
SCHUSS
709 RWHP & 677 RWTQ
SCHUSS's Avatar
Drives: 13' HPE 800 ZL1..... IOM vert, M6
11.34 @ 124.88
SCHUSS is offline   Reply With Quote
Old 01-05-2014, 10:03 AM   #28
AG1LE
AG1LE's Avatar
Drives: '14 1LE
test
AG1LE is offline   Reply With Quote
The Birth of Brandi's Twins [COTW 8/8/11] SSE 4 2SS Member Car Journals 9335 09-02-2021 01:09 AM
