Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 05-10-2011, 06:51 AM   #15
Hired Gun
Wild Man
Hired Gun's Avatar
Drives: 2010 Camaro
I would like to see pics of all sides of the car with this done and on.
2010 Camaro Black with White Stripes, Jannetty Racing Roto-Fab CAI, VMAX Ported Throttle Body, Long Tube Headers, GMPP Axel Back, Emblem Pros Custom "VOODOO" Under hood Bow tie, Chrome Gill Inserts, HUD plate, Sparks Performance White SS front and rear Plate MPD-1 Spoiler
Hired Gun is offline   Reply With Quote
Old 05-10-2011, 07:29 AM   #16
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
Honestly I have used weldcraft in the past and would only trust them with my life. The best reason to widen the rear is that you can go to 10.25 or even 10.50 with a spacer I believe. I dont like the idea of running a spacer on performance car. That being said many have done it with out issues.
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 05-10-2011, 09:34 AM   #17
barnesql
Drives: 95' Z28, 2010 2ss RS
@GQ4LIFE, I am sure people have had problems with spacers in the past. The kind that I used, and the kind that most performance shops recommend using are the hub-centric variety. It is also important to get a good brand, like H&R. The spacers are expensive, but you get what you pay for.
I would not recommend using a spacer that does not have its own studs, since you will only get a few threads to put the lug nuts back onto with. Of course, with any spacer you are putting extra stress onto the studs and the hub since you are furthering the distance in which the wheel is mounted. With that being said, a lot of guys in the business have told me that using a good quality hub-centric spacer, installed correctly, is safe.
BTW, I fit an 11'' widened stock wheel with a 20mm spacer, and no problems so far.
2010 Camaro SS - LS3
Magnaflow 3" Competition Series Catback
Off road x-pipe
Kooks LT Headers
barnesql is offline   Reply With Quote
Old 05-10-2011, 09:59 AM   #18
GQ4Life
Drives: 2010 Camaro SS LS3
Do the tires stick out past top of fender well
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 05-10-2011, 10:27 AM   #19
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
The rear wheels have a deeper dish than the fronts, so I want to leave them back there. I've seen photos of the rears moved to the front with the widened fronts on the back, and it looks goofy to me.
However, that's just a matter of personal taste. There are no technical problems with doing it that way, and a lot of people do it.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 05-10-2011, 10:33 AM   #20
kmcd
kmcd's Avatar
The tires will stick out less if you move the fronts to the rear. That is, until you add a spacer. In fact, that's why you need a spacer if you use the fronts.
If you just widen the rear wheels, the outside of the tire will be in the same place (approximately, depending on tire size) because you're only adding backspacing to the wheel when you widen it. As long as you don't go more than 10.5 inches, you should have enough inboard clearance without using any spacers.
Last edited by kmcd; 05-11-2011 at 12:46 PM. Reason: I inadvertently said "more" instead of "less."
Old 05-10-2011, 12:32 PM   #21
Hired Gun
Wild Man
Hired Gun's Avatar
Drives: 2010 Camaro
Cool. SO when you getting it done?
Old 05-11-2011, 12:37 PM   #22
kmcd
kmcd's Avatar
I've got the wheels ordered, and they should be here in a few days. I'm getting an extra set of 20x9s because I want to mount INVOs on all four corners and NT05Rs on the other set of rears for track days.
I'll take the extra set up to Dallas next week, hopefully, and they said it will take about a week to turn them around. This way I don't have any down time on the car. Once I get the first two widened, I'll get the INVOs mounted, slap them on the car, and then take the OEM rears back to Wheels America for the same drill. Then I can mount the track tires on those two rims.
Old 05-14-2011, 10:34 AM   #23
kmcd
kmcd's Avatar
O.K., I took a new set of OEM 20x9s up to Wheels America in Dallas yesterday. I should get them back in about a week, and I'll post up pics before I mount the tires on them.
Old 05-14-2011, 12:44 PM   #24
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Can't wait to see how this turns out. I want to have mine widened, but I did not want to go through the hassle of shipping the wheels. Good luck.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 05-14-2011, 11:43 PM   #25
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I'm having some done at Weldcraft. Their price to widen a 20" is now $275. Currently about a 5 week lead time. I'm having the rears widened. I think I'm going to widen to 10.5" so I don't have to run adapters. Are there any pics of rear wheels widened to 10.5" running a 315 tire and no adapter? I've seen the pics of fronts widened with adapters.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-15-2011, 02:10 AM   #26
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
I just had a pair of rear wheels widened to 10.5 inches. The tires (305 P Zeros) are on order. With the car on jack stands I mounted a wheel (no tire) on to see what kind of clearance there was. There was about a 1/2 inch clearance between the inside edge of the rim and the plastic wheel well liner. I figure with the 305 tire on and with bulge of the side wall there may be very little clearane. But, keep in mind that the suspension is unloaded and hanging at this point. The geometry will change with the suspension loaded, hopefully with more clearance. I'll find out when the tires arrive.
Cam 427 is offline   Reply With Quote
Old 05-15-2011, 12:47 PM   #27
kmcd
kmcd's Avatar
Originally Posted by yotaman96 View Post
...Are there any pics of rear wheels widened to 10.5" running a 315 tire and no adapter? ...
I"ll have some for you here in about a week. I'm going to mount 315 INVOs on the 10.5" rims I get back from Wheels America. Once I have them, I'll post up pics with and without the tires mounted, so we can see how much clearance we have (loaded and unloaded).
Old 05-15-2011, 12:51 PM   #28
GQ4Life
Anyway you can do straight pic from rear.. thanks
Pics of Customized STOCK wheels? DieselDork Wheels and Tires Talk Sponsored by The Tire Rack 5 04-20-2011 10:51 AM
stock wheels widening? Capthowdy Wheels / Tires 3 10-15-2010 09:12 PM
My wheel comparison: stock 20's vs. stock (1LT) aluminum 18's: A writeup ALLTRBO Suspension / Brakes / Chassis 12 05-11-2010 09:34 AM
Widening back of stock SS rear wheels flht99b Wheels and Tires Talk Sponsored by The Tire Rack 3 05-11-2010 08:54 AM
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill nUcLeArEnVoY Camaro Photos | Spyshots | Video | Media Gallery 129 04-22-2010 02:59 PM
