07-30-2015, 07:42 AM | #15 | |
Drives: 2010 Camaro 2SS/RS SLP Supercharged Join Date: Feb 2012
2010 Camaro 2SS/RS - Rally Yellow
SLP TVS2300 Supercharger; 3.6" Pulley; CAI Intake; 72# Injectors; ZL1 Fuel Pump; ADM Fuel Pressure Regulator; BBK Full-Length Headers; Cat Delete; Dynomax Cat-Back Exhaust; Eibach Pro-Kit suspension;ZL1 Front Bumper; NightOwl Lighting; '14 Heat extractor hood mod; Seibon CF trunk; GM High Wing and side skirts; Technostalgia Taillights; Pioneer Navigation; Infinity Subs and Amps; Scosche Double-DIN kit; CF cabin overlays; Z28 replica wheels; Hurst Line-Lock; |
11-24-2015, 04:57 PM | #16 |
Drives: my love Join Date: Nov 2015
hello everyone, i hope you are doing well, im new in this forum, i have camaro ss 2010 , today i experienced a problem in starting my car when i turn the key to position one and two everything going as it should be , but when i turn the key to start the engine, it died as there a battery problem, my battery is good , the fuses and rely are all intact, ,could anyone help me please
03-07-2016, 05:50 PM | #17 |
Drives: 2012 Camaro 2SS 2000 Camaro SS Join Date: Oct 2008
This just started on my 2012 2SS.
Saturday night got the Stabilitrack message, car felt like it was running on 4 cylinders. RPM gauge just flat-lined at 0 and unresponsive. Sunday the car ran like a champ. No errors, multiple start ups and stops, put about 200 miles on the car. Monday, (Today). Car started up fine, drove to work. Went to leave for lunch about 4 hours later and got the Stabili message. Tried it again 20 mins later and there was no message. I just took it to the dealer, they called and told me the crankshaft sensor was bad and needing replacing. Car only has 22k miles and is about 5 months over the 3 year mark. Not covered, $350 quote. :( |
03-09-2016, 03:10 PM | #18 | |
Drives: GM Vehicles Join Date: Jun 2010
I?m truly sorry to hear that your crankshaft replacement is not covered, because I know how inconvenient out of pocket expenses can be. Although I cannot guarantee a different outcome, I?d be happy to reach out to your dealership to discuss any possible assistance options. Please send me a private message with your full contact info, VIN, current mileage, and involved dealership if you?d like me to look into your situation further. I look forward to hearing from you, Corey K. Chevrolet Customer Care
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
03-11-2016, 03:03 PM | #19 |
Drives: 2014 silver rs camero v6 Join Date: Mar 2016
I have a 2014 camero rs that only has 5300 miles on it, the stabitrack lights comes on once and a while, has been to two dealers and they can not figure out why
03-11-2016, 03:07 PM | #20 |
Also when that message comes on the car is running just fine no misses or anything like that
07-20-2016, 11:06 AM | #21 |
Drives: 2015 Join Date: Jul 2016
2015 v6 same issue service stab and blinking CEL. Dealer having problems locating issue. 9000 miles, issue started heading down the highway about the 60 MPH. Experience acceleration problems.
08-09-2016, 09:45 AM | #22 |
Follow up
Car brought back to dealer, they had it for a week and could not find any issues. wife picked up car and engine light back on and experience poor acceleration again. Brought back to dealer and left running so they could see for themselves. Dealer had for 3 weeks, gm got involved. Code 6 cyclinder misfire due to faulty fuel injectors. Fuel injector test showed lean condition in 6 cyclinder. Dealer replaced all injectors on that side. Car runs great now with no issues. Dealer recommends only using top tier fuels. Customer only uses top tier fuels. Experience great service from GM and dealer considering the wild goose chase. Time to cruise on!
02-10-2017, 11:52 AM | #23 |
Drives: 2014 ZL1 Black on Black Join Date: Dec 2016
I've been having a very similar problem on my 2014 ZL1 6MT. Its completely bone stock, besides a resonator delete which has been there from the previous owner. I bought the car with 9,400 miles and it currently has 16,700 and I've only used premium gas. The past few days I noticed that the car started misfiring/stuttering at high rpm with heavy throttle. It will occasionally hesitate while getting the car moving, usually when I start off in second.
I get the 'SERVICE STABILITRAK' message (when doing heavy throttle) and this morning I got a flashing CEL. I have yet to check the code for the CEL, but I've checked the battery connection, spark plug wires and all connections and nothing seems loose. When I drive the car slow to moderate its un-noticeable. For the past 7k miles its been running fine and the only thing that's been done is an oil change about 1k miles ago and a new battery about 3k miles ago. It seemed like bad gas at first but I've filled up twice with premium since the problem occured and put almost a full bottle of Lucas Fuel injector cleaner. Will post more updates as I look towards solutions. I wish it was simple as an unplugged spark plug connection but I hope its not a cracked valve spring. |
04-26-2017, 08:48 AM | #24 | |
Drives: 2013 Camaro SS Vert L99 Join Date: Mar 2013
Having similar issues. Thought it was from an exhaust rattle setting of the knock sensors but still getting the P0300 with anything over half throttle.
06-02-2017, 07:05 PM | #25 | |
Drives: zl1 Join Date: May 2017
06-09-2017, 07:43 AM | #26 |
This had been a reoccurring problem, strangely only occurring during the summer months...finally got fed up, and began zip-tying all wiring harnesses that touch the frame or the block. Paid particular attention to the wiring harnesses coming from the TB, across the front of the engine, and down the sides, making sure the wire loom surrounding the harness is intact, and that the harness and loom are resting on the zip ties, not the block or frame. Since doing so, the 5v reference circuit error has not come back and the problem appears to be solved.
