05-14-2011, 11:50 PM | #15 |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
Just be sure to grind off some of the rib, or it will rub the frame. Look at the first two pics above. I'm sending pics and calling LPW on Monday to make them aware of this, so they can mod the covers before they ship them out.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
05-15-2011, 06:27 AM | #16 | |
Drives: VR ZL1 #259/Nissan 370Z NISMO Join Date: Aug 2008
If I already have an RPM transmission 3.70 gear diff, what would be the cost to send it to you to do the posi mod, billet caps and LPW cover!!! Thanks!! T |
05-15-2011, 05:56 PM | #17 |
Drives: cars Join Date: May 2011
What do the stock caps look like? Will the bolts work reasonably well on them? I assume it was designed to work with the stock setup primarily but it never hurts to ask. Anyone have a pic of the stock internals?
05-16-2011, 12:35 AM | #18 | |
Drives: 2010 SS Join Date: Nov 2009
I'm not a drag racer but I do drive her hard and agressive. |
05-16-2011, 07:16 PM | #19 |
Drives: Black 2SS/RS M6 Join Date: Mar 2010
mtcwby did you hear from lpw for having to grind off some of the case.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
05-16-2011, 07:26 PM | #20 |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
Ordered one of these today, nice looking piece.
05-17-2011, 09:54 AM | #21 | |
The load bolts put some preload against the carrier bearing caps to help keep them from flexing. If you've ever heard the drag racers talk about putting a girdle on their rear diff, this is what they are talking about. Yes, I talked to LPW and they said mine was the only one touching the frame so far. But to be sure, since there's no way to know, they are doing a little extra machining on all the covers to be safe for all the cars.
05-17-2011, 06:34 PM | #22 |
Yes, I talked to LPW and they said mine was the only one touching the frame so far. But to be sure, since there's no way to know, they are doing a little extra machining on all the covers to be safe for all the cars.[/QUOTE]
Good to know.
2010 LS3 2SS/RS M6
05-17-2011, 11:04 PM | #23 |
[QUOTE=mtcwby;3229806]Yes, I think it's worth it. Anything that will give you a little insurance is definitely worth it.
The load bolts put some preload against the carrier bearing caps to help keep them from flexing. If you've ever heard the drag racers talk about putting a girdle on their rear diff, this is what they are talking about. Thanks! I think I'll go ahead with this. |
05-18-2011, 08:04 AM | #24 |
Drives: 2010 White SS/RS L99 Join Date: Jun 2010
Will double check fitment - but have to say the JRE boys lifted that bad boy right up into position - no grinding needed. But as said, will check clearance. Thanks for the heads-up.
05-18-2011, 11:41 AM | #25 |
Drives: 2009 ZR1 Join Date: May 2010
Do these come with the bushing already installed?
05-18-2011, 03:05 PM | #26 |
No, but now would be a good time to install the Pfadt bushings!
05-19-2011, 09:58 PM | #27 |
Drives: 2010 SS/RS M6 Inferno Orangle Join Date: May 2011
Got my LPW diff cover today, the notch was already machined. Nice product!
05-19-2011, 11:09 PM | #28 | |
Show us some pics of the area that they machined.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Engine Cover and Manifold Cover for sale | ZZcamaro | Miscellaneous Items | 1 | 12-05-2010 07:19 PM |
aftermarket car cover | 011silver 2SS | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 15 | 11-03-2010 11:23 PM |
Car Cover | domano 68 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 19 | 05-21-2010 09:51 PM |
SS ENGINE COVER EMBLEM & NAMEPLATE 2010 CAMARO | Kirban Performance | V8 Bolt-Ons & Tunes | 0 | 11-30-2009 01:40 PM |
Putting on car cover alone, possible scratches. | OHIOSS | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 15 | 07-01-2009 09:40 PM |
