11-14-2023, 11:07 PM | #15 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
It's good stuff, and wayyy out of my league, but never the less we all have our specialty and Skilled Trade.
11-15-2023, 05:43 AM | #16 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Thanks for sharing such an awesome build! Like they say, if it were easy everyone would do it.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
11-15-2023, 06:19 AM | #17 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
I'll let you know of any road blocks if I come across any. Not a lot of info on people that "complete" the swap and what it took to do it. I feel like I did all the research I needed beforehand. For the most part it's just straight up mechanic work. Let's see how it plays out.
11-15-2023, 06:20 AM | #18 |
Secret to success is having the proper tool for the job, knowing how to ask the right questions, and some good common sense. I'm certain you could do it.
11-15-2023, 06:21 AM | #19 |
Thank you sir. I will keep you all updated as the build progresses.
11-16-2023, 06:39 PM | #20 |
Pedals are in, what a pain in the ass!
11-20-2023, 05:52 PM | #21 |
I just have to say your suspension setup is bad ass!
Nice job on the work so far with the TR6060 swap...I'm looking forward to seeing your progress. And BTW, your garage looks awesome. What brand of tiles did you go with on the floor? |
11-21-2023, 05:22 AM | #22 | |
The floor is GarageDeck, made by snap-loc. Absolutely love it and regret not doing it sooner. Million times better to stand/lay on than concrete.
12-04-2023, 06:05 PM | #23 |
MAJOR Milestone this evening.
Segment swapped the ECM with a manual trans calibration. Started without issue. I did cheat a bit, as I disabled the clutch interlock until I wire in the clutch position sensor. Currently no exhaust, MAF or cam sensor, and no trans but test fire started and ran a couple seconds, long enough to verify operation from the tune side. Only light on is the airbag light because the Driver seat is not installed and SES dues to cam sensor not connected. Very pleased with this! First Start Up next, get the trans in and the hydraulics working.
12-05-2023, 10:13 AM | #24 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
12-05-2023, 04:22 PM | #25 |
I'm very f'n hyped about this.
I went into this project with so little information on anyone that completed it "successfully" that would share info. I said screw it, I will figure it out as I go, hours of research on the topic and here I am. FWIW, there is a lot of misinformation on this. Modifying engine harnesses, and BCM programming, etc... I pulled the L99 harness, put in the LS3 harness. Read out my program in the ECM without the TCM connected. Segment swapped the ECM with with a M6 file of the same OS. Mechanically disabled the Key lock solenoid, although I know how to do it electrically and "may" do that before I button it up. Here I am, car is as happy as a pig in mud. 3 wires for the Clutch Position sensor and a relearn procedure, then all safeties are in place and working. Mechanically, it all works with exception of the clutch pedal. No hole in the firewall. No biggie, fabbed a template and went to town on making the hole. It started the first attempt and there was no can bus faults, all modules present and accounted for. She's happy and so am I!
12-06-2023, 10:14 AM | #26 | |
Anthony S
Did you add a seperate reservoir for the clutch fluid?
12-06-2023, 12:29 PM | #27 | |
I much prefer manual for my toys, wasn’t gonna get rid of the car, so swap it is. I mounted a separate reservoir here, and was able to use the stock line. I’m happy with it.
12-06-2023, 07:01 PM | #28 |
Drives: ABM #93 Join Date: Oct 2018
bad ass! Congrats on the huge progress so far! Can’t wait to see it in and on the road!
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
