Old 01-23-2019, 01:19 AM   #15
Cooter42
Drives: ZL1 1LE
I have never seen E-Track on aluminum trailers. Is there a reason for that or I just haven't seen it done?
I plan to do Option 3 for the front and Option 1 for the rear.
I have an aluminum trailer w etrack and over the wheel straps - been fantastic so far.
Cooter42 is offline   Reply With Quote
Old 01-23-2019, 08:09 AM   #16
Rodan
Rodan's Avatar
Drives: 2018 ZL1 coupe
Originally Posted by 2010REDSS View Post
I use Macs thru the wheels and they work fantastic. COTA is 17hrs one way, Road Atlanta is 12hrs, never a problem and the car never moves.
I cross the fronts and that allows for no contact with the splitter, and don't cross the rears as the D-rings are actually inboard the wheels a bit so the car can't move laterally.
Really simple, fast to do, and the Macs straps are the bomb.
What length straps are you using?
Rodan is offline   Reply With Quote
Old 01-23-2019, 08:36 AM   #17
2010REDSS
2010REDSS's Avatar
Drives: 2018 ZL1 1LE
Get Mac's Kit #511658 and select the 40" Axle Straps option - they are long enough to go through 11" and 12" wide wheels. (And they are of course fleece lined to protect your wheels). I also got the 8' long Direct Hook Ratchet straps. The Direct Hook option is really nice.
Go here....
http://www.macscustomtiedowns.com/pr...Tie-Down-Packs
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 01-23-2019, 08:37 AM   #18
Pollock
LT4 M6
Pollock's Avatar
I have an aluminum trailer as well. I bought the Macs through the wheel option. I bought the extra long option because I didn't want to be to short but the standard length kit would have been fine on my 20ft trailer.
The etrack is probably a better bet but, with straps, aluminum Etrack, plus the other stuff needed I was looking at spending $750 vs $270 for the through the wheel option. I think the shorter kit is $250.
Pollock is offline   Reply With Quote
Old 01-23-2019, 09:22 AM   #19
kaamacat
Drives: 2018 ZL1/1LE Red
This weekend I will put the car on trailer, and, also see where the beams are under the platform. (check to make sure if I go eTrack I can access the bolt-nuts...etc). The MACs OverTire is ~$305 and 4x8' sections of T6061 eTrack is ~$240... So lets call it $550 in total. (And when this started my wife said "Can't we find a trailer for about $2500?.....my answer was.... N O P E)
BobR
2018 ZL1 1LE (Red) - New Dec 2017
2015 ViperGT (Gunmetal w/Red stripes)
2013 ZR1 Anniversary
2014 ZL1 - BrightYellow, 6sp
2011 Porsche GT3RS - White w/red graphics
2009 Porsche C2S
2001 Ferrari 360
kaamacat is offline   Reply With Quote
Old 01-23-2019, 09:36 AM   #20
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Etrailer.com buddy, WAY cheaper.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 01-23-2019, 10:39 AM   #21
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
I'm not a huge fan of the thought of the through the wheel straps rubbing the brake dust into the wheel finish, with the other the tire straps the wheel face never gets touched.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 01-23-2019, 11:30 AM   #22
Pollock
LT4 M6
Pollock's Avatar
Once you call Mac your bill goes up. They sell track with the hardware. Or you can buy it yourself but lots of nuts and bolts add up. I was going to use Stainless fasteners.
Old 01-23-2019, 11:31 AM   #23
kaamacat
Looking at the T6061 for tracks to keep the unlike metals from corroding. (Thinking any coated... whether paint, powder or even zinc, once mounted firm against the bed, those areas rub down to steel)
BobR
2009 Porsche C2S
2001 Ferrari 360
Old 01-23-2019, 11:32 AM   #24
Pollock
LT4 M6
Pollock's Avatar
I was worried about that also but after 3 track days my wheels have road rash from track abuse. Lots of micro chips. Over time that will add up. So does it really matter in the end.
Old 01-23-2019, 11:33 AM   #25
thanks
There is a special trough the wheel option. I just run straps through the wheels with some microfiber towels under them.
Old 01-23-2019, 03:43 PM   #26
Rodan
Rodan's Avatar
Go here....
Thanks!
I already have MACs straps that I use for my Miata, was just wondering what size wheel straps you went with for the ZL1 wheels. I figured it would probably be the 40"...
Old 01-23-2019, 07:40 PM   #27
fosterelli
Drives: 2019 ZL1 1LE
I also use these on our 32' gooseneck.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
fosterelli is offline   Reply With Quote
Old 01-30-2019, 06:58 AM   #28
kaamacat
Did you go with Aluminum track, galvanized, powered coated?
BobR
2009 Porsche C2S
2001 Ferrari 360
