07-16-2021, 02:02 PM | #15 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Poster number 7, the reason is they last a long time. I had one in a car for 14 years. Get the Everstart Maxx!
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
09-15-2023, 01:49 PM | #16 |
Drives: 2011 Chevy Camaro 2SS A/T Join Date: Feb 2020
I have poor cranking on hot and going to replace my battery. I am the second owner and found that installed 100 AH battery non AGM. I am looking through the rockauto and all suggested batteries are AGM-type. Is it crytical that battery should be AGM and 80 AH ? Our car doesnt have a start-stop, I wounder why AGM is mandatory ?
09-15-2023, 02:08 PM | #17 | |
Drives: 2012 camaro ss Join Date: Sep 2018
GPI Powered
09-15-2023, 04:42 PM | #18 |
Drives: 2011 Camaro rs Join Date: Jun 2023
09-15-2023, 05:02 PM | #19 |
Yep....^^^
09-15-2023, 06:48 PM | #20 |
I bought an AC delco AGM. it lasted a yr. Here’s the thing with batteries. Go to place that sells them frequently. That way you’re ensuring a new battery. Nothing wrong with Walmart batteries
Life is short, drive it like you stole it! |
09-15-2023, 07:38 PM | #21 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Check ALL ground locations for corrosion. These cars are getting older & one bad connection will cause you fits. I went through all mine last winter when I swapped motors & some were marginal. The car can now sit for a month & crank fine.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
09-16-2023, 12:10 AM | #22 |
thank all for reply... But please advise., does car real need AGM type battery
09-16-2023, 06:27 AM | #23 |
Drives: 2013 ZL1 Join Date: Sep 2021
Either will work an AGM battery won't leak acid in your trunk if it gets a crack in the case. Places like Rock Auto sell AGM because shipping a conventional lead acid battery is extremely expensive due to leak potential.
09-16-2023, 06:56 AM | #24 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
09-16-2023, 09:45 AM | #25 | |
https://www.camaro5.com/forums/showt...ttery+problems
09-24-2023, 02:30 PM | #26 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Interstate. I have an Interstate distribution center here that also accepts drive ins/counter sales. Sometimes they will have “blems”. These are brand new batteries with a missing or torn label, scratched case, etc. They carry less warranty but a $250 battery will be $65 bucks. I always check for a blem in the size I need first.
09-24-2023, 05:55 PM | #27 |
Funny this thread popped back up. I'm in the market for a new battery since my old "flooded" LA battery puked all in my trunk. I'm going to replace it with an AGM batery this time. I was looking at the AC Delco Gold AGM, the Duralast AGM, and the Diehard Platinum AGM. The only way I can get the AC Delco is through Summit Racing, and I kinda don't trust the shipping handling through UPS. They don't handle things very carefully, or I could order it through the dealership for an arm and a leg. I looked at the Walmart Everstart Maxx's AGM batteries and the were the cheapest. But I have never bought any batteries from Walmart. I see some of you have. The AC Delco from Summit is only 175 bucks, the other two are 250-260. Walmart was 179. I haven't driven the Camaro since I had the issue and took the battery out. Been researching and shopping for AGM's.. I've learned a lot about them though! Just can't make up my mind. Don't want to cheap out on one either.
09-25-2023, 01:10 AM | #28 |
Never buy the cheapest.
You should buy the battery from a battery store,because they are not "already old". |
