04-17-2014, 06:22 PM | #15 |
The Beast
Drives: 13 2SS/1LE/RS/NPP/NAV/SUNROOF Join Date: Apr 2013
I just thought about it....its impossible to be 180* off...as long as your at 6cam-12crank
N.F CAM, P&P HEADS, SLP UDP, C.A.I., TRI Y'S, BMR 1" SPRINGS & SWAYS, PFADT TIE RODS & TRAILING ARMS, TUNED BY MATT@FSP 490HP/428TQ
04-17-2014, 06:23 PM | #16 |
The Beast
did you have backfire with the new cam?
04-17-2014, 07:51 PM | #17 |
Drives: 2011 2ss/rs M6 Join Date: Jul 2013
did you check your pushrod length and lifter preload??
Summit white 2011 2ss/rs ls3- New Era performance cam-New era OTR intake-PRC CNC ported heads-OBX long tubes-NPP cat back-3:91s
dyno numbers soon |
04-17-2014, 08:21 PM | #18 |
Drives: cars Join Date: May 2011
You wonder why a large untuned cam isn't running right? Even if you did have an issue you won't be trouble shooting anything like that.
04-18-2014, 12:18 AM | #19 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
PR length seems a little short for that that cam imo. I've personally never used anything that short with a NF cam install.
You can't get the camshaft 180* wrong since it's pinned and you'd have to literally have the timing mark on the Cam gear at the 1:30 (ish) position if that were the case. Lifter preload shouldn't be an issue unless you have a collapsed lifter. It's a straight 22 ft/lbs of tq at each rocker and it's done. Even the rowdiest of camshafts will start right up normally and the car will run untuned long enough to capture DTCs or at least tell if it's running right. P0300 is perfectly right in this situation. It will need and require a tune or will run like crap. Good luck and let us know if we can be of any tech help to ya. Ivan @ Southwest Speed |
04-18-2014, 02:47 AM | #20 |
The Beast
Well I've got some loud noises from the passenger side valve train....from inside it almost sounds like a squeaky belt....but its coming from the area of cyl 4.....I pulled the valve cover and everything seems inline and tight....what will a compressed lifter do?
And Ivan I had preordered the 7.425(due to recommendations) and checked the pushrod length(had some trouble at first due to measuring on cyl #1 exaust due to checking cam6-crank12, and not 12-12....first time measuring Sent from my HTC One using Tapatalk
04-18-2014, 03:14 AM | #21 | |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
2010 Camaro SS LS3 - No Modz
04-18-2014, 03:22 AM | #22 | |
The Beast
A video of the valvetrain noise....
04-18-2014, 04:12 AM | #23 |
Eh, that'll happen
Start it with the valve cover off and see if you can pin point it.
04-18-2014, 04:20 AM | #24 |
The Beast
I did but couldn't tell....it's louder with the cover on....
04-18-2014, 04:25 AM | #25 |
Eh, that'll happen
Did you check the underside of the cover to see if there was any marks? Im almost wondering if when you were putting your pushrods in, you caught the lip of the lifter instead of the bowl, and when the pushrods comes up, its causing the rocker to hit the cover. Kinda hard to diagnose not standing next to the car. That squeaking noise can be the push rod rubbing against the block because its at an angle.....
04-18-2014, 04:33 AM | #26 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Wow thats terrible. Sounds like somethings touching. Like not enough rocker to spring retainer height distance. Maybe a bad lifter or to much/not enough preload.
Thats terrible though.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
04-18-2014, 11:41 AM | #27 |
The Beast
How would you know?
04-18-2014, 11:48 AM | #28 |
The Beast
Okay guys whats the first thing I should do/check...pushrod length on passenger side (I only checked #1)....what else...Pull the head and look @ the lifters.....kinda at a lost....tow it to a shop
