12-22-2022, 06:11 PM | #15 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Why, yes! Yes, you would. I sometimes forget some folks run cats. I'm just a mid-pipe w/o cats since I'm mid-mount turbos. You'd want BOTH sensors (NB and WB) pre-cats; running all four O2 sensors with the ECU and the WB(s) via an external gauge/controller or to the data logger (e.g., HPTuners).
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
12-23-2022, 04:25 AM | #16 |
Drives: 2013 ZL1 Join Date: Sep 2021
It is always recommended to mount the sensor before the cats. The readings after the cat are almost identical so if you want to use the rear O2 location go for it.
12-23-2022, 04:31 AM | #17 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Thank you sir but I no longer have the rear o2 bungs since now I have a TSP exhaust system. But I do have cats. So my wideband o2 can go into the pipe right after the header then before the cats?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
12-23-2022, 04:52 AM | #18 |
Yes keep in mind mounting position, the tip of the sensor needs to be pointing down slightly so condensation doesn't drip into it.
12-23-2022, 10:07 AM | #19 |
^^^ good advice. I would also make sure the sensor isn't in the draft of the sensor in front of it as well. Obviously you want a nice exhaust stream reaching the sensor.
12-23-2022, 11:41 AM | #20 |
This is a beside-the-point information insertion: when I compared the HPTuner data log and the dyno sniffer log, there was a 1/4-sec delay from the two sensors, meaning, if your tuner isn't using your laptop and the installed O2 sensor closer to the motor (they're using the exhaust tip sniffer), then the tuning won't be dead nuts on with your fueling. I don't know if that's close enough, or that I'm just over analyzing the effort.
12-23-2022, 11:57 AM | #21 | |
12-29-2022, 08:41 AM | #22 |
Recent post on HPT forum that is interesting
https://forum.hptuners.com/showthrea...l=1#post711333 Post 33 |
12-29-2022, 09:41 AM | #23 | |
" It includes two analog outputs (wideband 0-5V, and narrowband 0-1V) for interfacing with 3rd party devices and one digital serial output for interfacing with the DM-6 gauge and other Multi Gauges. The wideband analog output is ideal for interfacing with aftermarket ECU's and data loggers. The narrowband output is ideal for stock narrowband oxygen sensor replacement where the simulated narrowband analog output is fed back into your ECU to make it operate as if the stock narrowband oxygen sensor is still installed while running the PLX wideband setup." But as it states it has two analog outputs but it doesn't say if it's linear or not. So I'm not sure, I'm just scared to run two different o2 sensors because there could be descriptions between the two in terms of the time it takes to read each banks A/F ratio and send it back to the ecm and therefore changing each banks fueling requirements.
12-29-2022, 09:48 AM | #24 |
Just doesn't seem worth the possible issues to save getting another bung welded in.
12-29-2022, 09:53 AM | #25 |
Yeah I agree.
01-06-2024, 09:58 AM | #26 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
I'm just marking this Thread because it got tons of great info
