Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 02-21-2024, 06:22 PM   #15
aris
Drives: Z/28
If your LS7 is stock, run high flow cats. If you have a head and cam package and track the car, you'll probably blow out the cats after a few events.
I ran high flow cats with my 1 7/8 ARH headers and ultimately blew out one of the cats after 2 track events (which also clogged up my mufflers).
aris is offline   Reply With Quote
Old 02-21-2024, 09:34 PM   #16
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
hey Joelster, I believe you... but which cat remover would you recommend? kooks come with high flow cats and I think they are welded into the headers
2015 Red Z/28.
Seattle area
void_kp is offline   Reply With Quote
Old 02-21-2024, 09:35 PM   #17
void_kp
void_kp's Avatar
2015 Red Z/28.
Seattle area
Old 02-22-2024, 07:26 AM   #18
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
Ideally, 2 inch LTH are best for the port shape of the LS7.
any 5th gen 1 7/8 LTH should also work however.
I had a swapped LS7 and reused my 1 7/8s from the LS3. Worked just fine.
rich2342 is offline   Reply With Quote
Old 02-22-2024, 11:21 AM   #19
aris
Drives: Z/28
Confident that they are not welded onto the headers
Old 02-22-2024, 09:33 PM   #20
void_kp
void_kp's Avatar
I checked and you are right. any recommendation on where I can find a bypass tube without having to spend a kidney for it?
2015 Red Z/28.
Seattle area
Old 02-23-2024, 07:28 AM   #21
IdahoRob
Drives: 2014 Z28
My Kooks came with high flow cats AND blank tubes to replace the cats if desired.
IdahoRob is offline   Reply With Quote
Old 02-23-2024, 05:19 PM   #22
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
They shouldn't be welded. When I ordered mine, I ordered the non-catted h-pipe or whatever it was.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 02-23-2024, 06:31 PM   #23
Coz3z3
Drives: 2015 Z/28, 2015 1LE
What brand did you use? And was it a crate LS7? Did you swap anything over from the LS3? The reason I ask is because our oil coolers are larger than one from an LS3 and that's what the headers hit when you just use any 5th gen header. The headers made specifically for the Z/28 (from Kooks and ARH) are designed to go around the stock oil cooler found in our cars. The ports are not the issue. It's the oil cooler. I was also told from Stainless Works that their headers will not work with the Z/28 because of this issue.
Now if you were to delete the stock LS7 oil cooler, any 5th gen header would fit just fine. I don't know if this is with every brand header out there, but I know I wouldn't risk trying it unless I was deleting the oil cooler.
Coz3z3 is offline   Reply With Quote
Old 02-26-2024, 01:14 PM   #24
Toolie
Toolie's Avatar
I guess billy boat exhaust isn't specifically for z28? 1-7/8 vs proper 2"
https://youtu.be/2iJBvHABbVI?si=JPrAPc7GOGkb0jRK
2015 Z28 SIM AC/Speakers #1228
2011 RAM 2500 6.7 diesel
2018 Husqvarna TE300
1985 Yamaha RZ500
Toolie is offline   Reply With Quote
