07-03-2017, 04:10 AM | #15 |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
I had a friend who did the same thing in his '99 LS1 T/A... ran fine for a week and then lost compression on a cylinder. Full rebuild was necessary. Money shift! Had another friend who did the same thing in his older M3. Same deal.
Good luck. Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
07-03-2017, 07:16 AM | #16 | |
Drives: Slow Join Date: Mar 2016
2016 Toyota 4Runner
2017 Camaro ZL1 |
07-03-2017, 08:24 AM | #17 |
Drives: 2009 Corvette ZR1 Join Date: Aug 2012
I'd keep an eye on oil pressure...
07-03-2017, 08:38 AM | #18 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Well, a short duration can cause valves to bend. How do I know? My son over revved our 15 1SS a few years back when he pushed in the clutch and the throttle stuck to the rubber weather mat. He bent all 8 exhaust valves and 2 intake valves in a matter of a split second.
07-03-2017, 08:40 AM | #19 |
Also, the damage was severe and the car would turn over but not maintain and had massive bucking. We tried once to turn it on, and then stopped once we heard it struggle.
07-03-2017, 09:09 AM | #20 |
Drives: Pre-production ZL1 M6 Join Date: Feb 2016
I almost did this in my 17 ZL1 but Active Rev Match saved my butt. I was about to drop into second but heard and saw the the ARM system blipping the throttle so high (but not over revved) I knew it couldn’t be 4th. Luckily my brain quickly sent a message to my foot not to release the clutch and I quickly corrected my mistake before disaster struck.
07-03-2017, 09:17 AM | #21 | |
Drives: 2018 ZL1 1LE Join Date: Feb 2009
Over-revving on a downshift will spin the engine beyond the redline - the computer will cut fuel and spark but the mechanical ratios will spin the engine and the valve-train beyond it's limits. That said - also agree - if it is running normally you likely came out ok. Take it to your dealer and have them check it out to be sure.
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
07-03-2017, 09:49 AM | #22 |
I just drove it this morning, everything seems to be acting normal. Found out the e85 kit was rubbing the brace slightly after which was causing the dash rattle I thought I had. When it spun up I tossed it in neutral so I think that might have helped too
2016 Toyota 4Runner
2017 Camaro ZL1 |
07-03-2017, 10:24 AM | #23 |
Drives: ZL1/335i Join Date: Apr 2014
If it didn't immediately start running rough or making abnormal noise, there's a very good chance it's fine. Bent valves are usually the outcome if you mechanically over rev the engine badly enough.
And just as an FYI, most manufacturers aren't going to warranty engine damage caused by a "money shift". If a manual trans car comes in with bent valves, the first thing the manufacturer is going to want to see is max engine speed. I know companies like BMW want vehicle data read out and transmitted prior to authorizing an engine, cylinder head, etc. Pretty sure GM has a similar policy. If it was over revved, it's going to likely be on you. |
07-03-2017, 10:45 AM | #24 |
Drives: Acura MDX Join Date: Dec 2015
Your biggest concern might be warranty coverage later down the road. Chances are you didn't hurt anything as others were saying. However, the dealer should be able to tell an over rev occurred and the total duration. If something goes wrong down the line it's possible they will deny any warranty claims as a result even if it wasn't caused by tou. This is a common theme I've seen in other forums. The only good news here is that it's a chevy not a BMW. If something did go wrong you could get it fixed without going bankrupt.
Previous - 2006 350z 6M, 2008 335i Coupe 6M
Current - 2015 RC F, 2016 MDX Future - ? |
07-03-2017, 11:37 AM | #25 | |
Drives: 2017 ZL1 Join Date: May 2012
http://www.roadandtrack.com/new-cars...-to-the-track/ |
07-03-2017, 11:40 AM | #26 | |
Retired from Car mfrs....
07-03-2017, 11:51 AM | #27 |
Drives: 17 ZL1 Join Date: Mar 2017
I honestly do not think 7500 for a brief moment would shatter your engine, anything higher definitely would have been a money shift. If the car is driving fine I'm sure its fine.
07-03-2017, 11:57 AM | #28 | |
Tracking and missed shifts aren’t considered abuse, long duration downshift over revving and other childhood nonsense is. |
