07-15-2022, 08:22 AM | #15 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Lol I didn't realize I was in this forum, I must have clicked on it by mistake as I do not normally visit this one.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
09-01-2022, 04:24 AM | #16 | |
So a new updade for you guys, after ordering the Thermostat and the Intake Mainfold Gasket, driving to the Workshop he Told me that this pipe and an other pipe were also leaking.
And also This Pipe So now everythis is done now and I've driven for two week now with no problems, but i have the feeling this isn't over jet. I have the clue that the Heater Core is also leaking a bit and this yould be very expensive to repair. But I'll keep you updated on it |
09-01-2022, 08:02 AM | #17 |
Why do you think the Heater core is leaking? If you are still smelling antifreeze I have found that Dex Cool can smell for a while after the leak even if it was cleaned well.
12-12-2022, 10:10 PM | #18 |
Drives: Silver LS Join Date: Aug 2009
update?
Hi Unbecoming,
Following your post since I am having an increase in operating temps recently. My mechanic suspects the thermostat, but the repair is about $450. Since the operating temp isn't acutally overheating (212F) I continue to drive it. But I'm not taking long trips and I monitor it closely. I have 216K miles and worried about those heater pipes and core as well. Let me know if you are happy with the thermostat replacement.
Silver LS - manual, white stripes, black interior, and those swell 18" black steelies! (18" Bavarian aluminum in the garage). |
01-14-2023, 05:20 PM | #19 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
If its worth anything, my radiator cap failed and was leaking, Take it off and check the bottom O-ring, if its flattened replace it.
It was not keeping the proper pressure / fill level.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
Tags |
coolant leak, overheat, overheating |
