11-10-2017, 03:38 PM | #15 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Going back to the track in the next week or two. Ill try locking it next time and see what happens. I have a smaller pulley on the way for the ysi so hoping for 9's. Im gonna have to run the 1/8 to get the tune dialed in i got booted last time for not having a cage. So you lock it in 2nd and keep it locked during the shift? I thought that was a bad idea
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
11-10-2017, 03:38 PM | #16 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Probably drop 50 lbs from skinnies and decrease rolling resistance. Any weight reduction would help your cause. You should also go quicker from the great air we have right now too.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
11-10-2017, 04:12 PM | #17 | |
Drives: ZL1 Join Date: Mar 2016
There is a track rental at MIR (Budds Creek, MD) November 18th. You will not get kicked out. Might be worth a trip. DA will for sure be in the negatives & excellent track. |
11-10-2017, 05:09 PM | #18 |
Track rental next weekend at cecil county too. Chance of rain though
11-10-2017, 05:11 PM | #19 |
11-11-2017, 05:32 AM | #20 |
Drives: Synergy Green SS Camaro 6 speed Join Date: Sep 2014
Listen to prostock John
Synergy Green Camaro SS LS3 TH400, Stock Ported heads, Night Fury cam 4600 Circle D stall. 3.91 gears and rotofab intake, obx headers,
11-11-2017, 07:14 AM | #21 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
The 4L80 needs more gear. Do the 3.73's ASAP
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
11-11-2017, 02:27 PM | #22 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
More gear is needed with the 4l80 your trap rpm are way low. I am running 391 with the 4L trapping in mid 6000 rpm at 135 mph.
Wheel and tires will help. But more gears will do more for you.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
11-11-2017, 04:32 PM | #23 |
I ordered the 28 tires, and I'll complete the 3.73 swap as a winter project.
Regarding the 3.73 swap, if I were to purchase the complete carrier from GM, how difficult will it be to swap ZL1 carriers on the floor without the luxury of a lift? |
11-11-2017, 05:02 PM | #24 |
Drives: Camaro Join Date: Mar 2013
As PSJ said, I run those tires with a similar set up as you. 1.41 60 ft, 6.44 1/8 but I have 3.73 gears.
11-11-2017, 05:14 PM | #25 |
11-11-2017, 05:44 PM | #26 |
11-11-2017, 07:50 PM | #27 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
It's not hard, pretty basic stuff, I've done a few on jack stands. there are a few diy write ups. A small little transmission jack is nice to lower and raise into place if by yourself. A second hand a regular jack will get it done also. Check out the classified see the complete zl1 diffs going for 1200-1500ish and you can sell the one you took out for almost as much
11-11-2017, 09:31 PM | #28 | ||
