08-03-2021, 11:49 AM | #15 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Forgot to mention that I used eraser wheel, works 100x easier.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
08-03-2021, 12:23 PM | #16 | ||
Shadow Gray '19 ZLE M6
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
08-03-2021, 12:44 PM | #17 |
Welcome! I hadn't either until several years ago seeing one used to remove pin stripe and immediately bought one. It's not something you use very often, may even forget you have it, BUT rubber doesn't deteriorate over time so it's always ready to do the work for ya.
08-03-2021, 01:48 PM | #18 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Never heard of eraser wheel but, I won't forget it's available, THANKS.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
08-03-2021, 01:53 PM | #19 |
ALWAYS-N-BOOST
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
08-03-2021, 02:27 PM | #20 |
https://www.aliexpress.com/item/4000993445124.html
If someone doesn't mind waiting a month, here's the "direct from manufacturer" version of the Amazon emblems, lol. I'm 99.9% sure they're identical, but both have slight differences vs the OEM emblem....BUT their dimensions are extremely close to each other.
08-03-2021, 04:19 PM | #21 | |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
08-03-2021, 04:21 PM | #22 |
so which one are you all using for the front? any links?
08-03-2021, 06:11 PM | #23 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
That is my plan
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
08-03-2021, 10:00 PM | #24 | |
Differences I noticed handling both emblems at separate times... None anyone else would notice while on the car though. Chinese emblems feel like they weigh more OEM bottom is slightly contoured The red inlay is larger on Chinese The red inlay is not removable on Chinese, has clear epoxy over The red inlay on OEM is more sunken in (not counting epoxy) The 1 seems to be slightly different.
03-07-2022, 02:05 AM | #25 | |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
03-07-2022, 04:10 AM | #26 |
All black on mine.
Hood and rear bumper emblems from Amazon. Flowtie, grille emblem, and center caps are all painted.
2018 Camaro ZL1 A10
03-07-2022, 07:37 AM | #27 | |
I painted my heat extractor gloss black to contrast the carbon. Rear and rear was in NFG, again to offset them against the black paint.
03-07-2022, 07:40 AM | #28 |
These badges and center caps look so good and tasteful they should be a factory option, with a royalty paid to you
