09-23-2022, 05:51 PM | #15 |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
It's not heat soak. It has only happened on cold starts after the car has been sitting for several days.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
09-23-2022, 06:22 PM | #16 | |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
You are obviosuly having an issue since you are throwing codes but watch this video to better understand why the long crank happens on cold starts. It is normal and has to do has to do with meeting emissions.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
09-23-2022, 06:24 PM | #17 |
09-23-2022, 11:46 PM | #18 |
Thanks. That definitely explains why the engine has to crank over for a while before it fires. The problem is with my engine it either doesn't fire during the cranking process or it fires and then shuts off. It's clearly not getting enough fuel at start up when this happens. And it doesn't happen every time I start it when it is cold.
09-24-2022, 08:07 AM | #19 |
The high pressure fuel pump is in charge of maintaining rail pressure. There is a solenoid which controls the amount of fuel entering the pump. It gets a PWM control signal from the ECM. I think the solenoid may be sticking. Finicky behavior related to temperature can be a sticky solenoid.
09-24-2022, 09:07 AM | #20 | |
09-24-2022, 10:42 AM | #21 |
Hot Camaro
Can't tell if you if there are any codes when it has happened, but my car has had some long-crank starts that resulted in not starting, starting fine, or starting with erratic idle and backfiring (shutting it down and starting again allows it run correctly). The longer the car sits without being started, the more likely this is to occur. I only had it occur once on me this year, though, and it was the first start of the season after sitting for 4.5 months and experiencing a dead battery while it was sitting.
09-26-2022, 08:13 AM | #22 | |
I'm going to take it back to the dealer this week and let them check the code again and suggest that they check the solenoid that controls the amount of fuel going into the fuel pump to see if it might be sticking.
