#15 | ||
![]() Drives: Camaro RS 2016 Join Date: Feb 2022
#16 |
Also is it okay for o2 sensor to have such fluctuations across the board? Shouldn't it be more smooth or something?
#17 |
O2 sensor could be the problem.
Do you have left and right on the V6, to compare the readings? |
#18 |
#19 |
![]() Drives: 2023 V6 RS 6MT Join Date: Mar 2023
Still troubleshooting?
2023 V6 6MT: Riverside Blue, RS, Recaro, Brembo, NPP exhaust, GMPP suspension [view my build journal]
mods: BC Forged RZ21 19x10, Conti ECS 265/40, front splitter, FE4 front sway + endlinks, FEA rear sway + toe links prior cars: NB Miata, C5 Z06, NC Miata |
#20 |
#21 | |
![]() Drives: 2023 Chevy Camaro 1SS Join Date: Jan 2023
I am currently having this issue however I believe this all started happening because of my AFM delete plug, I unplugged it and plugged it back in as the car was on and this is when the p0420 code came up and my car started skipping every so often when cruising, it's misfiring in cylinder 3 (according to a shop I took it too)... Any ideas of what it do to fix it or if those two problems have a relation to each other? |
