03-13-2020, 06:40 AM | #15 |
Tiresize.com is a good website to use when comparing different tire sizes on wheels and it also tells how much the speedometer reading changes too!
03-13-2020, 11:11 AM | #16 | |
What speed limit?
Drives: 2017 SS 1LE Join Date: Jul 2019
03-13-2020, 11:18 AM | #17 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
Hey i get it. Heres something. Measure the tire bead across to the oher bead where the rim sits. Now measure the rim. If the rim is an inch smaller well, there ya go. A 30 35 series will not bulge like a 50 series just too short. I only speak from experience. You can put a 305 on a 9.5 rim and it fits fine on the front with a spacer and no poke. Hey but thats a 12.3 width tire that wont work. It will on a 9.5 because its not a 12.3 anymore.
Does it work to put a slightly wider tire on a too small rim to get better traction? . Yes up to a point it does. Is the center going to wear out faster than the edge yes. would you get better traction if the complete tire was wearing the same yes. Can you wish away the laws of physics lol no lol. stock tire on 9.5 some spinning notice how it wears. 285 on stock rim more spinning notice how the center is nearly down to the wear bars and the outer is like near new lol.also their is a effect of camber being like 1.6 i think it was. got it to .7 now Anyhow fyi |
03-13-2020, 11:21 AM | #18 | |
03-13-2020, 11:25 AM | #19 | |
That wear is from over inflation. Run flats like less tire pressure similar to drag radials. The tire pressure monitor system is set too high in these cars. 555r's need to be down around 22-24psi and the run flats need to be 28-30psi. If 555r's are not hooking for you then you likely are running too much air in them or we are not talking about the same tire. 555g2 isn't remotely close to the same thing as the 555r.
Fwiw, When I was basic bolt-ons I went from consistent 4.0-4.1 0-60 with stock run flats to 3.8 with 555r's at 28-30psi. I dropped them down to 24-25psi and ran consistent 3.5 0-60 with a best of 3.4. Big difference!! Quote:
https://www.nittotire.com/competitio...g-radial-tire/
2016 NFG 1SS A8
03-13-2020, 01:30 PM | #20 | |
03-13-2020, 02:07 PM | #21 | ||
Drives: E92 BMW M3 Join Date: Oct 2012
305/30ZR20 103W XL 211220 11.0 27.24 12.32 10.5-(11.0)-11.5 1929 @ 50 34.24
J-Rod Built and Matt@FSP Tuned |
03-14-2020, 11:18 AM | #22 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
When I went with new tires and wheels, I went with the Nitto 295 on a 10" wheel.
Yes, the 295 will fit on a stock 9.5 wheel but a 10" wheel is recommended for 295, 305, and 315. They fit with no prob. |
