03-19-2015, 01:41 PM | #15 |
Drives: Four wheels and an engine Join Date: Sep 2014
Not to replace but as an upgrade. Make it an option for the V6 models. Could share MANY of the same components keeping costs in check. I'd envision it like the 4.3 V6 to 5.3 upgrade in the trucks.
03-19-2015, 01:53 PM | #16 |
Drives: 01 Alero GLSV6/ 07 ZX-14/ 06GTO Join Date: Mar 2015
[QBhobbs;8305648]I doubt we see any other displacements than 6.2 liters. I would be surprised to see any new LTx engines at all.[/QUOTE]
I wouldn't say new LTx per say but look how the LSx platform changed a significant amount for three car CTS-V LSA ...ZL1 LSA vs the ZR1 LS9....or the old 346ci ls1 from 315-405hp ls6...I know its complete speculation. ..but V6..detuned V6 TT...and LT1 |
03-19-2015, 01:56 PM | #17 |
[QUOTE/BryceClark89]I wouldn't say new LTx per say but look how the LSx platform changed a significant amount for three car CTS-V LSA ...ZL1 LSA vs the ZR1 LS9....or the old 346ci ls1 from 315-405hp ls6...I know its complete speculation. ..but V6..detuned V6 TT...and LT1[/QUOTE]
A detuned LF4 would still cost the same or more than the LT1....so no. Will the LT1 get a displacement change over its life time....possibly.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
03-19-2015, 02:35 PM | #18 | |
A detuned LF4 would still cost the same or more than the LT1....so no. Will the LT1 get a displacement change over its life time....possibly.[/QUOTE] More than likely your correct. ..I just don't see the need for the Current 2.0t in the camaro...the LT1 is so flexible in its applicatiom why use it..i doubt chevy has a need to follow fords actions that much ....thoughts?
Owned lifted 88 dakota two door short bed V6 4x4, Yellow/black LB9 powered 85 IrocZ28 MODS Edlebrock intake, throttle body spacers and mass air flow sensor, Edlebrock full exhaust, K&N drop in's, B&M 700r4 shift kit. 2001.olds alero GLSV6, BIKE~ 2007 Lazer Metallic Blue ZX-14
03-19-2015, 02:39 PM | #19 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
not sure I really care what the ATS-V weighs. Yes, it is Alpha architecture but so is the CTS-V, all three vehicles will be their own vehicle. Now, if 6amaro gains weight over 5th Gen, then maybe we should be disappointed.
Just my opinion on the matter. P.S. I like my coined term for 6th Gen Camaro, 6amaro. brevity is nice, probably just me though. |
03-19-2015, 02:57 PM | #20 | |
03-19-2015, 03:04 PM | #21 | |
Also, does the TT V6 weigh more than an LT1? |
03-19-2015, 03:04 PM | #22 | |
The 2.0T's biggest reason is Euro market like it is for the Mustang. There are severe taxes on engine displacement there.
03-19-2015, 03:07 PM | #23 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
Im sorry... but, why is weight an issue again? GM made it perfectly clear that the new Camaro WILL be lighter than the 5th Gen.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
03-19-2015, 03:11 PM | #24 |
Drives: 2016 F150 Join Date: May 2014
It's going to be lighter.
03-19-2015, 03:17 PM | #25 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
My 2015 Malibu LTZ tips the scales at a bit over 3600 lbs, and The 2016 is supposed to be 300 lbs lighter.
If GM can shave 300 lbs off the Malibu, they should be able to shave a few hundred off the Camaro. I predict the 6th Gen will come in at right about 3700 lbs. |
03-19-2015, 03:18 PM | #26 |
Pardon my anxiety. .over weight. .but if your 350lbs and you lose only ten lbs...not really able to wave a flag look at me look at me I lost weight..but if your 350lbs and you lose 150 lbs then we can talk...remember how the new Mustang was "Supposed" to be lighter but actually gained weight ...not saying that will be the case for the gen 6 ...but for god sakes if GM wants to stick it ford...it need to be That 200 lbs lighter or that why its an issue...besides when exactly did 3600lbs become acceptable. ...
03-19-2015, 03:20 PM | #27 |
3600lbs would be a Fantasy come TRUE! 3700 in all likelyhood. Any less is just icing!
03-19-2015, 03:23 PM | #28 | |
Drives: 2013 1LE Join Date: Feb 2012
It became acceptable when safety requirements dictated 16 airbags. And consumers decided that sports cars need power everything and touch screens and keyless entry and all of the things the expect in a s-class Mercedes. I don't know why people think they can have everything and lose weight. Every gadget adds weight and wiring and adds up.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013 |
Tags |
engine speculation |
