Old 05-21-2024, 02:04 PM   #15
Tyrolblue67
Drives: 2019 ZL1 Camaro
It was on YouTube.
Done by "Super Car Sweden"
Search YouTube for ZL1 oil pump replacement Sweden.
Tyrolblue67 is offline   Reply With Quote
Old 05-22-2024, 12:44 PM   #16
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Originally Posted by nighttowl View Post
Its 5 more hours work to pull the engine and put a cam in.
No, It's 5 more hours work for you. for me it's 5 weeks, and maybe 5 months
Bangkok_ZL1 is offline   Reply With Quote
Old 05-22-2024, 12:48 PM   #17
Bangkok_ZL1
ZL1 Believer
Originally Posted by pauly1119 View Post
I dropped my car off this morning to have my oil pump replaced this morning and did my due diligence to find a known mechanic that works on Corvettes and Camaros. Mine is being done just to make the car better not as a repair. Hopefully his reputation precedes him.
you replacing the oil pump for precaution?
Old 05-22-2024, 12:52 PM   #18
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Yes exactly. Funny thing is I use to think people are crazy for doing it. My warranty expires this August so I decided why not, I spent the same amount on PPF. I did the pump, timing chain and damper.
pauly1119 is offline   Reply With Quote
Old 05-22-2024, 01:48 PM   #19
Bangkok_ZL1
ZL1 Believer
Originally Posted by Tyrolblue67 View Post
I came across a recent Youtube video of a shop in Sweden replacing an oil pump on a Gen 6 ZL1.
They didn't remove the engine. They loosened the motor mounts enough to raise the engine a bit. This enabled them to completely remove the oil pan. Clean off all the mounting surfaces then re-install everything.
Looks like a big job. I don't think I would trust a dealer service department do mine if it was ever needed.
I "think" Katech would actually remove the engine to swap out the pump?
I wasn't able to attach the link.
Perhaps someone else here with more proficient cyber skills can?
Just thought I'd share.
Tyrolblue67
there is the link. But after watching it. Doing this job myself would be exceptionally scary. That was a lot of stuff to pull
Old 05-22-2024, 02:57 PM   #20
Tyrolblue67
Are you replacing the oil pump with the Katech unit?
If not, the GM oil pump in your 2019 is the latest "improved" and "stronger" version that was installed by the factory.
These latest versions don't have the higher failure rates as the 2017 and 2018 do.
Although there have been some oil pump failures in 2019+ cars but far fewer than 2017 and 2018.
Tyrolblue67
Old 05-23-2024, 03:54 PM   #21
mayracn
mayracn's Avatar
Drives: 2017 zl1
Originally Posted by Camfab View Post
I wouldn’t trust a dealer to do any work on my car, period. Even if the tech’s are good. It’s a business, and they are motivated to get the job done as quickly as possible, so they can move on to the next job. The more work they do the more they make.
Well its called business. Nobody doing the work as a favor.
KOOKS LONG TUBES
AWE EXHAUST
ROTOFAB
FLEX FUEL 55% E TUNE
PORTED THROTTLE BODY
mayracn is offline   Reply With Quote
Old 05-24-2024, 12:39 PM   #22
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
They didn’t remove my front bumper, dropped the subframe and suspended the engine. It took a total of 1.5 weeks because we had to wait on a few small parts I missed. I supplied most of the parts.
