11-10-2016, 07:26 PM | #211 |
The 1LEs are a mono tube and the rubber in the upper mount is a harder durometer than the SS mounts.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components. Last edited by olblue75; 11-14-2016 at 09:09 AM. |
01-08-2017, 04:05 PM | #212 |
Drives: 2015 1LE Join Date: Oct 2016
Is there any confirmation that the zl1 motor / trans mount, 20952437 / 20952439 are different than what the 1le has? Also, I'm guessing if so the zl1's are stiffer? Tried researching a definite answer, but no luck. Thanks.
01-17-2017, 07:13 PM | #213 |
Drives: 2019 Chevrolet Camaro SS 1LE Join Date: Nov 2016
I have a question concerning the rear shock absorbers:
What is the difference between part number 22812987 ($333.65 through GMPD) and part number 231115372 ($207.60 through GMPD)? The description for the latter specifically indicates "w/ FE6 suspension." I'm officially confused. |
01-19-2017, 10:04 AM | #214 | |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
The difference in part numbers for the shock may also be due to 23115372 being JUST the shock. No other parts are included (no dust cover, bumper bushings, nut, etc).
06-16-2017, 09:51 AM | #215 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Ok ,so that's the new part number for the rear shocks for the My 2014 1Le ?? I'm doing 1.25" lowering springs . I already changed the fronts struts about 4000 miles ago . And my car is coming up on 47k so why not change them out too ..
08-24-2017, 08:39 PM | #216 |
Christina
Drives: Red Jewel Tint 1SS Join Date: Dec 2010
I have a 2011 SS and there's more play in the front shocks then there should. Could someone guide me in the right direction as to what parts I need?
Sent from my iPhone using Tapatalk Pro |
05-30-2018, 02:54 PM | #217 |
Drives: 2015 Camaro Z/28 Join Date: Jan 2011
Part number / description correction
Just wanted to see if we can get these part numbers corrected in the original post.
Front Strut (1LE) (passenger side) - 22812984 Front Strut (1LE) (drivers side) - 22812985 The numbers are good but the sides are incorrect. 22812984 is actually the drivers side. Ask me how I know |
11-01-2018, 10:48 AM | #218 |
Can anyone confirm the part #’s for the front struts ?? I found what I believe is a new number for replacement struts !! 22922603 right & 22922602 left ??
Thanks |
11-01-2018, 03:43 PM | #219 |
USA-1
Scotty, the post above yours has the part numbers...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
11-01-2018, 05:24 PM | #220 |
Ok ,that’s what I thought ! But just wanted to make 100% sure
10-20-2019, 07:54 AM | #221 |
HomezSS
Drives: 2014 SS/RS Camaro, 2011 Silverado Join Date: Jul 2014
ok -great thread here. I have a 2014 SS Vert and think I am due for struts all around next spring - so starting to do my homework. has anyone upgraded their vert to 1LE? I have been reading this thread - but skipped from 2012 (around page 3) to the end, and looking on line at GM wholesale sites have gotten some different info. here is what I think I need:
Front Strut (1LE) (passenger side) (1) 22812985 Front Strut (1LE) (drivers side) (1) 22812984 Rear Shock Mount (1LE) (passenger side upper) (1) 22922446 Rear Shock Mount (1LE) (driver side upper) (1) 22922445 Rear Shocks (1LE) (2) 22812987 or Rear Shocks (1LE) (2) 19300042 any help is appreciated
HOMEZSS
2014 SS/RS, FR Style 41's, 20x10x4, Borla CatBack with Touring Mufflers w/Magnaflow Glasspacks, Cold Air Inductions Intake, Diablo 91 Octane Tune, Firm Shift, AFM off, BMR cradle inserts, trailing arms and toe links, 1LE/ZL1 Rear Sway Bar, Jannetty Custom Tune for mods noted above (noticable change to how the car drives!!), JL Audio XD700/5 amp and 10 inch Sub, Focal PS 165K's, special wiring kit and amp board, and lots of dynamat (Amazon version) - Sounds GREAT, Runs Even Better! Last edited by sehovarter; 10-20-2019 at 08:34 AM. |
10-20-2019, 09:16 AM | #222 |
I’d do the Bilstien B-6’s from Summit.
Orange Krush II
01-08-2020, 08:09 PM | #223 |
Liv'n The Dream!
As long as this thread has been around and no one has gone to the OP and corrected the incorrect numbers of the Driver's side / Passenger side struts? WTF?
THEY ARE FLIPPED!!!! https://www.gmpartsgiant.com/Page_Pr...19ab1970cadfc5 That cost me about $100! Thanks
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
08-28-2023, 10:39 AM | #224 |
Drives: 2015 Chevrolet Camaro SS 1LE Join Date: Aug 2023
Sorry to bring up an old thread. Just purchased a 2015 1LE and mechanic showed where passenger rear shock was leaking so looking for OEM replacement. I see the number changed but it says discontinued. Any idea of where to get replacement OEM rear shocks? Ones I see on rock auto all say w/o performance package so not sure if that applies to the 1LE or not. Thanks for the insight.
