Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 10-07-2016, 04:06 AM   #197
opossum
opossum's Avatar
Drives: 2013
Originally Posted by vgradio View Post
I have read your previous posts in this thread, and I understand that you have connected your head unit to your new amp directly (with rca cables I guess).
I did the same in my car, with a metra kit, and I have lost all car generated sounds: chime, back up parking sensor and so on. The reason seems to be coming from the mylink unit swap, as it gets these information from the BCM I guess.
Does this new kit retain these sounds in your case? And if so, how does it work?
THANK YOU
Hallo,
yes, i have connected the amp direct with rca cables. The wire to activate the amp i have connected to the red wire, so the amp will be activated, when i switch the ignition to position accessories.
The kit has included a cmx chime module, that is connected direct to the pac-interface. I have deinstalled my center speaker in the dash, routed the cable for connecting cmx chime module to the center speaker place and then connected the module. All chimes are audible fine, all car sounds will be reproduced and the volume is good, pitches are habituation need, but they are there and distinguishable.
Chevrolet Camaro - V8 - MT - 2013 - European Version - Inferno Orange/ Inferno orange - ACC Sidemarker ghosted - Dash Kit PAC RPK5-GM4101 with DNX8170DABS - Amp KAC-8406 - Sub Pioneer TS-WX110A - Rear- and Front-Camera - ACC Mail Slot Scanner RGB - Pedders Sportsryder - painted parts in engine compartment - black powder coated original rims - H & R wheel plates 20mm front and rear axle - 1 LE steering wheel - MGW Short shifter replacement - aluminum door Pins - ACS T4 Splitter - us-mirrors - ZL1 side rockers - High Wing Spoiler
opossum is offline   Reply With Quote
Old 10-07-2016, 10:43 AM   #198
Beast6162
Beast6162's Avatar
Drives: '12 Hennessey Vert & '17 50th Vert
Originally Posted by Low Saturn View Post
Is the camera located on the top center or bottom center of the grill? Any pictures of what it looks like on the new radio with the camera on?
Thanks..
The camera is on the top center of the lower grille (it was a really tight fit and I am not able to adjust the camera up and down, but luckily the angle is about perfect so i got lucky). I'll take some pictures showing the install location on the car and some shots of the view from the HU. I had some earlier shots from the HU but they were taken when the front end of the car was laying on the ground while I was testing to make sure everything worked before putting the front end back on the car.
Shoot straight, shoot often and share what you learn...My tactics instructor use to say "it doesn't matter what you carry, but you can never have enough ammo!!"
2012 Hennessey HPE600 Camaro Convertible Black, Inferno Orange Synergy stripes
2017 50th Anniversary Camaro SS Convertible
Beast6162 is offline   Reply With Quote
Old 10-07-2016, 08:06 PM   #199
kain929
kain929's Avatar
Drives: 2012 2SS, Silver, Borla S Type, CAI
Originally Posted by rydahog View Post
i have the reverse camera in my mirror and i got the gen5diy adapter that moves it to headunit from mirror. plug n play...or he also has one that both HU/mirror can still be used.
So, what about the cam harness that comes with the kit? Is it only for use with cars that have mylink?
kain929 is offline   Reply With Quote
Old 10-07-2016, 10:58 PM   #200
Beast6162
Beast6162's Avatar
Thanks..
First picture is of the camera mounting location on the front end, I couldn't get a better picture tonight.
Camera view 1 wide angle
Camera view 2 regular view
Camera view 3 Top down view
Camera view 4 split screen looking right and left
Old 10-08-2016, 05:59 PM   #201
kain929
kain929's Avatar
Can anyone tell me what these two connectors are for? I know the black one is for the antenna and the other one is a mystery. They were both connected to my factory hu. Any help would be appreciated.
Old 10-08-2016, 06:56 PM   #202
rydahog
rydahog's Avatar
Drives: camaro ss
black is am/fm...other is xm or onstar..maybe someone can chime in about that
rydahog is offline   Reply With Quote
Old 10-08-2016, 09:28 PM   #203
Skyset
Drives: 2017 Camaro 2SS Coupe
I am just waiting on my kit...have a stereo all picked and ready to go
Skyset is offline   Reply With Quote
Old 10-09-2016, 12:30 AM   #204
kain929
kain929's Avatar
I didn't realize that I needed a micro bypass so that I can get around the parking brake connection. This was way more work than I anticipated. I should have spent the $150 to have it installed. Oh well, too far into it to stop now.
Old 10-09-2016, 12:34 AM   #205
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
The other one is for XM.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 10-09-2016, 05:41 AM   #206
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
Micro bypass 13bucks amazon well worth it
RLNTLSS is offline   Reply With Quote
Old 10-09-2016, 07:03 AM   #207
Chaotic73
BUMBLLB
Chaotic73's Avatar
Drives: 2010 Camaro 1LT/RS
Does anyone know if the kits offered by Double D Mods included everything that is needed for the install?
Chaotic73 is offline   Reply With Quote
Old 10-09-2016, 07:40 AM   #208
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
The kits are offered by PAC and sold by Phastek (Sponsor) and other vendors.
The instructions were provided in post #25
The rest of the thread pretty much provides everything else you need to know
Snoman is offline   Reply With Quote
Old 10-09-2016, 07:46 AM   #209
Chaotic73
BUMBLLB
Chaotic73's Avatar
Sorry, I was referring to the Kenwood Radio package they sell that includes the PAC dash kit.
http://shopddmods-com.3dcartstores.c...e--_p_437.html
Old 10-09-2016, 07:50 AM   #210
Snoman
H-Town Camaro Club
Snoman's Avatar
I'm not understanding your concern exactly, what is it you believe could be missing?
