04-05-2024, 08:42 AM | #1933 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Pumpkin gets some new stopping power for this years road course outtings.
04-05-2024, 09:29 AM | #1934 | |
04-05-2024, 01:50 PM | #1935 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
I really need to get my Zl1 calipers powder coated so that I can do this swap myself. Was it hard to bleed them? Do you need a power bleeder or can you just do it the old school push the pedal and turn the bleeder way?
These came out looking really good. How different is the stopping power? Have you already taken them out for a run?
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
04-05-2024, 06:15 PM | #1936 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Very nice. Love the new setup.
Which Motive kit is that? I need to acquire one myself!
04-12-2024, 02:47 AM | #1937 | |
In The Circle
04-12-2024, 02:54 AM | #1938 |
In The Circle
Not sure I've had it for several years now. You just need the base kit and add the correct cap for the brake reservoir or modify a stock cap. I recommend getting the billet alumimum cap though.
04-12-2024, 02:59 AM | #1939 |
In The Circle
Yep! and a Quick Jack to get your car off the ground in your new garage and your set to go.
04-12-2024, 03:04 AM | #1940 |
In The Circle
Just waiting for the call now to trailer Pumpkin to Lyons Auto Craft for an attitude adjustment!
04-12-2024, 03:11 AM | #1941 |
In The Circle
Just a heads up if you only use it once and a while you need to flush it out with a weak solution of Simple Green before you store it away for next time!
04-27-2024, 09:23 PM | #1942 |
In The Circle
The GPI Stage III cam install has begun.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Can ring and pinion be installed w/ pumpkin in car? | GMRULZ | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 2 | 01-19-2011 07:33 PM |
Pumpkin Fixed | Merc | Canada | 12 | 10-24-2010 08:38 PM |
Nekoosa Pumpkin Fest | blackgoldhtr | USA - Great Lakes | 1 | 10-14-2010 08:18 PM |
Pumpkin Gets Signed | Merc | Canada | 9 | 09-03-2010 11:12 PM |
Pumpkin is moving to the city | Noah | 5th Gen Camaro SS LS LT General Discussions | 0 | 11-27-2009 01:12 PM |
