10-13-2011, 10:55 AM | #169 | |
Drives: 2010 IOM Camaro Vin 34334 Join Date: Oct 2008
Acutally Pill your right as usual. To drop the cradle is the correct way to change the cam. Have done several myself and its the easiest way. now if your talking 4th gen camaro, then you dont have to do the cradle, vette yes its a hell of alot easier. There is no damn room in the vette to do the work. 5th gen camaro havent done so dont know. Last edited by Hesh; 10-14-2011 at 10:28 AM. |
10-16-2011, 06:30 AM | #170 | |
Drives: '11 Mustang GT Premium Join Date: Oct 2010
Back on topic, I have heard from more sources that Ford turned their noses up at another big bore modular idea (Cammer 5.0). Therefore, this new 5.8 most likely will be a new engine that was conceived in a similar fashion that the 5.0 was. Using tooling from the 5.4 and possibly from the 5.0 (5.0 blocks are made in Romero), the cost to build the engine are drastically reduced. I could have swore that the Nurburgring Cobra's sounded like a Condor 5.4 because the 5.0 and 5.4 use different firing orders giving them distinct sounds. Since this is a new engine being based on both the 5.0 and 5.4, either firing order could be used... I have also heard that this engine will use TiVCT not only for the smooth power curve but also to escape the gas guzzler tax on a 600-620hp V8. I will also bet that engine weight will also come down slightly but additional equipment should see some more weight added to the whole package but nothing too crazy (about 20-40lbs). Weight is still being looked at and a simple transmission swap and wheel upgrade could see this Cobra dip into the ceiling of the 3700lb range (3799 if they are lucky). This is all rumors at this point but I have heard this from more than a handful of people... I have heard that Red is at Lommel and Black is still home in Michigan (I am not going to Belgium or Michigan to confirm this)... Their benchmark car is from Japan... I guess it makes sense since Ford gave Nissan PTWA for the GTR and Nissan is loaning Ford the Track Ap for the Mustang.... I wonder what else they got for the PTWA . Anyway, we are possibly looking at a power to weight ratio of 6.1 which will excite those that wish to race the car. With the addition of 0.4 liters and using the old Eaton M112, the 5.8 would be capable of close to 600hp (591hp, 547tq) as is, an additional 0.5 liter supercharger will easily push this monster over the 600hp mark. Using TiVCT and extra displacement will reduce the stress on the engine that force induction is associated with while maintaining 23mpg highway rating. Edit: As of late September, the 2013's have been on lockdown so info will be harder to come by until next month. Last edited by thePill; 10-16-2011 at 07:17 AM. |
10-16-2011, 03:50 PM | #171 | |
Drives: police interceptor Join Date: Nov 2008
rear end, Beefier Wheel/Tire package, Magna Ride 3.0 and Performance traction managment. Just have to wait and see. |
10-17-2011, 04:28 AM | #172 | ||
Nurburgring is fun, fun to be there and fun to watch... There is currently no GT500 lap time and probably never will be. Cars that are fast at Nurburgring usually are not as fast worldwide or.. they have extreme difficulty doing lap 2 because of brake fade, heat soak or tire wear. There are very few cars that are truly track ready and I am sorry to say that the GT500 or the ZL1 is not in that category... Why build a car tuned to just one track, and before you assume that the Boss 302 was tuned on Laguna only, you would be wrong. The Boss was tuned during the 2010 Grand Am season my Multimatic on every US track on that circuit during race conditions. 0-60 and 1/4 mile traction is being looked at and I am betting that this new car will throw up numbers better than the aftermarket GT350 in that department. As far as a single lap goes (all the supercharger is really good for), the new SVT is mainly focused on distancing itself from its little brother and stepping closer towards something much faster... Quote:
10-17-2011, 11:34 AM | #173 | |
10-17-2011, 11:45 AM | #174 | |
Drives: 4 Wheels, Gasoline Engine Join Date: Jul 2010
10-17-2011, 12:34 PM | #175 | |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
10-17-2011, 02:41 PM | #176 | |
You see my point? I think somebody bought some PR, I'm just not sure if it was Ford selling it Edit: In road racing, driver comfort is important. I believe it was C&D that stated the need for more seat grip is always needed to generate great times. Although their run was slower than Ford's (137mph vs. 142mph) the car still handles very very well and was balanced (not just fore and aft). If we start adding in things like; lightweight racing seats, 5 point harnesses and more chassis support then we start adding not only driver comforts but chassis comforts as well. A single cross bar can add significant improvements to foot pounds per degree resistance. A roll cage increases the amount of rigidity the chassis has. Whenever a car goes through a turn at high speeds (Nurburgring), it generates massive lateral gravitational forces. These G Forces generate high amounts of stress in the vehicles chassis. This causes chassis flex, in which a roll cage can reduce, limit and sometimes stop all together. Chassis flex can have devastating effects on your vehicles suspension and handling. Chassis flex can cause the suspension’s geometry to change. Chassis flex can alter camber degree, toe and caster. With a roll cage installed and depending on how complex it is, a roll cage can make chassis flex almost nonexistent. This means that while a car appears to be fast on a track that has high speed turns, once the additional structure is removed from the car, the chassis will become unpredictable and handling will become much worse. Looking at both the GT500s and ZL1s roll cage systems, it is safe to assume that the structures could absorb 10,000 to 30,000 foot pounds of force per degree due to the aggressive cage system layout (that is between 100 and 250%). That would mean that even under 1.5gs at 100+mph, the tires would still remain in contact with the road... something 99.9% of production automobiles cannot vouch for... The car would remain flat... The extra 100lbs would do little to offset the vehicle now that the car was solid and in motion, from a stop... weight would hurt it... at 100+mph, it would attribute to less than a 1% increase in G forces during turning (Depending on speed). And who knows what else is going on in the car... this was in fact a tuning run if I remember what GM's North American president said... Now, every run in a Camaro from now on has to be done with a full cage, the next run will be with Cup tires I'm sure... Anyone who thinks that additional support from a 12-16 point roll cage "helps a little" and the fact that a strut tower brace "is a very ridged bar that obviously get us.. you know, an incredibly precise track performance" ~ Mark L. Ruess (and it does) isn't very smart... The chassis estimates are from NASCAR and are no way accurate because I do not know the specs on the cage but with an aggressive cage system (see ZL1), I am willing to bet that resistances are increased by at least 100% over nominal. I will say this again, reality is far from Nurburgring... a place where nobody can challenge your times and some people are eating this PR with a spoon Last edited by thePill; 10-18-2011 at 07:39 AM. |
10-17-2011, 03:43 PM | #177 | |
Drives: 2005 STi corn fed Join Date: Jul 2008
10-17-2011, 08:52 PM | #178 |
Drives: bug Join Date: May 2009
Any word about the possibility of 5.8L getting the 2.3L TVS?
If it get's the 2.3L TVS, I'm most likely going to trade up because that will be one dominant engine package considering the 5.0L is running easy 10's with that charger on top of a stock 5.0L. A lot of other vehicles in the Ford lineup have dual clutch automatics and one can only hope that they develop one to sit behind this new 5.8L as an option. That would truly make it a killer on and off the track. Heck they might as well do an electronic diff just like they did in the new GC SRT-8 and F-430's which could propel it to 60 in under 3.5 seconds with launch control if they engineer it correctly. I'm hoping I like the updated styling of the new 2013 model, people who have seen it have reported its a love it or hate it sort of look. I've never been a Mustang guy until I saw the 2010 GT500 and didn't want to buy one until I heard of all the upgrades for 2011 so I just might keep mine if the 2013 update look's like crap. |
10-18-2011, 04:53 AM | #179 | |
Another thing to think about is the 5.4's parts are going to get a lot cheaper after the 5.8 is released. Unless Ford continues the 5.4 for catalog sales only (possible), I would expect the engine price to drop along with the parts themselves. If the engine remains in the catalog, the engine will probably stay at the current price point and only see the parts being reduced for clearances and such (see old 302, 4.6, Cammer 5.0). It is a big decision and I can honestly tell you that I love the 2010-2012 Mustang looks the best... Is this new Cobra going to be $60k to start? then it might not be worth it... If it starts at $50k then put your stock wheels back on and trade up once you get the details on the internals. Also, the 2013 GT500 could very well have large rear disc brakes.. it might be difficult to use 15" wheels for drag racing with brakes of that size (size unconfirmed but look to be over 13") and the front brakes look larger too (could be 15"). Something to look into if you intend on drag racing and may have to swap out the big brake kit or, get new wheels with offsets. I had heard a while ago that the "Drag pack" might make a comeback but never did any follow up. (pray for a Drag Pack) Anyway, check out the new Steeda functional race wing, I think it would look great on your GT500. Edit: Not trying to cause you any more moral conflict Dan but.... This is a place holder pic from the LA Auto Show debut website for new cars Dun dun daaaaaa!!! Per request from Ford's Jim Farley, all SVT Mustang's will come equipped with baseball bats (I made that up... sorry Jim) Last edited by thePill; 10-18-2011 at 07:56 AM. |
10-18-2011, 02:27 PM | #180 |
1 n the head,2 n da chest
Drives: 2002 cadillac deville Join Date: Apr 2010
you are going to need more cubic inches.
2011GT E85, Kooks 1-7/8", 3" offroad X, 2-7/8" overaxles, Roush mufflers, CobraJet intake, SCJ monoblade throttle body, drew 4.5" CAI, Boss302S exhaust valve springs, Baby CobraJet exhaust cams. 3.73 gears, lightweight 300A. 455rwhp @7800/410rwtq SAE 5000lb roller dynojet
10-18-2011, 02:57 PM | #181 | |
mid engine, or at least exotic looks. it would mean breaking from tradition. i doubt that can happen. the vette can be faster and more powerful than EVERYTHING, and its still just a vette. use the 1970 chaparral as a baseline.
10-19-2011, 05:08 PM | #182 | |
Drives: 2013 ZL1 Join Date: Mar 2010
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
CEL - P1682 | PSU SS | Tuning / Diagnostics -- engine and transmission | 4 | 09-29-2011 07:27 PM |
Roto-Fab | Cold Air Intakes | Engine Covers | Washer Reservoir Relocation Kit | Fuse+ | AutoAgenda | V8 Bolt-Ons & Tunes | 7 | 07-11-2011 06:50 PM |
Engine Cleaning With Pictures | Angelo@Autopia | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 4 | 05-01-2010 11:00 PM |
Why i think you cant do a Dyno in the same day | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
