dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 03-21-2018, 08:10 AM   #17571
tstodii
Drives: White 2015 Z/28
Originally Posted by Ghost7997 View Post
Looks Great! Really turned out
I think it repels more than just water and dust....
tstodii is offline   Reply With Quote
Old 03-22-2018, 01:44 PM   #17572
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
New Topic for Discussion
2019 Cadillac CT6 V-Sport Twin Turbo V-8 First Look - Cadillac Only??
Although the CT6 flagship sedan has been making do with the same four- and six-cylinder engines that power its lesser siblings, Cadillac has been itching to go toe-to-toe with the best A-list German sport sedans. Boss-man Johan de Nysschen or his immediate predecessor managed to convince the corporate purse-string minders that a high-torque hot-V twin-turbo DOHC V-8 was the price of entry to this elite club, and that dagnabbit, that price was worth paying! So sure enough, sometime in the first half of next year, the 2019 Cadillac CT6 V-Sport will offer the brand's first exclusive engine since the Northstar. One irony before we delve into the deets: At least initially, the engine will only be offered in the U.S., Canada, and the Middle East, leaving the autobahns unchallenged.
As noted, this 4.2-liter engine, internally code-named GF18, is a clean-sheet design adhering to most of the latest trends. It features a smaller 86.0mm bore and longer 90.2mm stroke, a strategy that favors low-end torque, tolerates higher compression (9.8:1—pretty high for a boosted engine), and leads to improved thermal efficiency. It also enables closer bore spacing—96.0 mm, down from the Small Block's 111.7 mm, which shortens the block, crank, and all four cams for significant mass savings. Speaking of the crankshaft, it and the eight connecting rods spinning it are made of forged steel and the piston pins feature a diamond-like coating to withstand stress and reduce friction.
The valvetrain includes cylinder deactivation of the number 2, 3, 5, and 8 bores. There's variable timing on all four cams with 55 degrees of adjustability on the exhaust side and 70 degrees on the intake side. Even better, when switching the engine off (auto stop/start is standard), the intake cams park at a position in the middle of their travel affording no exhaust/intake valve overlap for easier starting and a smoother initial idle. Fuel is always injected directly into the cylinder at high pressure (up to 5,000-plus psi), as there were no operating conditions requiring the addition of port injectors.
The cast stainless steel exhaust manifolds incorporate the housings for the twin-scroll Mitsubishi Heavy Industries turbochargers. The titanium aluminide turbine wheels (half the weight of Inconel) spin up to 170,000 rpm to produce as much as 20 psi of boost that gets relieved via electric wastegates. Bolted directly to the back of each turbo is a 19-liter catalytic converter. These two cats provide all the after-treatment the engine needs—and they greatly complicate the under-hood thermal management, which includes electric fans and water pumps that will continue running long after engine shut-down, following a session of prolonged hard use. An intercooler mounted just above each cylinder head reduces the charge air temperature by 130 degrees F immediately before it whooshes into the outboard intake valves. (Perhaps needless to say, this engine requires premium fuel.)
Two variants of the engine will be offered—each of which will be hand-assembled and personally signed on the Performance Build Center line at the Bowling Green Kentucky Corvette plant. The top version will produce 550 hp at 5,700 rpm and 627 lb-ft at 3,200-4,000 rpm, or 500 hp at 5,000-5,200 rpm and 553 lb-ft at 2,600-4,600 rpm. The difference is primarily in the tuning, with the only mechanical difference being a more restrictive (quieter) exhaust on the lower-output version. That compares reasonably well with the German hot-V twin turbos, including Mercedes-AMG's 4.0-liter (469-603 hp and 479-664 lb-ft depending on application), Audi's 4.0-liter (450-605 hp and 406-516 lb-ft), and BMW's 4.4-liter (552-600 hp and 500-553 lb-ft).
Both variants will come bolted to a 10-speed automatic transmission and feature all-wheel drive to ensure every pound-foot of leverage gets a purchase. The transmission will include the very latest Performance Algorithm Shift programming to ensure it's always in the right gear, even when you lift for a turn.
It's interesting to note that Cadillac claims the 2019 CT6 V-Sport's engine is both smaller on the outside and lighter than the supercharged LT4 and LT5 Small Block V-8s, weighing in at a claimed 529 pounds. Small enough to squeeze into an ATS engine compartment? "I've never been asked to look at packaging it in an ATS," replied assistant chief engineer John Rydzewski. It would certainly fit in an Escalade engine bay and go a long way toward differentiating that truck from the Yukon Denali that's forever nipping at its Manolo Blahnik wedge heels. Expanding availability to the Escalade would certainly pay off the development costs a lot more quickly than the 1,500 or so engines per year that are currently forecast for the CT6, but truck volumes would surely nix the handcrafted one person/engine assembly idea.
We're not sure what the engine will be called (for now it's unimaginatively dubbed Twin Turbo V-8), or how vehicle badging may differ to distinguish the power levels. Also unknown—whether there will ever be a straight-out CT6 V, and if so whether it will use this engine. We were led to believe there is a bit of "head room" to stretch output of this engine, perhaps by de-stroking it to 86mm (4.0 liters) and spinning it a lot faster. For now, we're assured that this engine targets a more refined power than a V badge portends.
2cnd chance is offline   Reply With Quote
Old 03-22-2018, 03:08 PM   #17573
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Cadillac is back! (?)
JusticePete is offline   Reply With Quote
Old 03-22-2018, 08:07 PM   #17574
2cnd chance
That engine is very interesting. 627 TQ Sweet!
Old 03-23-2018, 12:40 PM   #17575
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
The ME vette motor... done.
Schlok is offline   Reply With Quote
Old 03-23-2018, 01:42 PM   #17576
Bhobbs
Bhobbs's Avatar
The ME Corvette is likely getting a 5.5 liter twin turbo.
Old 03-23-2018, 05:18 PM   #17577
pat_t
Drives: .
One thing is for sure, given the development cost of those technologies, that engine will definitely be going in a number of other vehicle platforms... It's just a case of which ones?
I'm assuming it's not going into Europe cos they can't get it through emissions regs.
pat_t is offline   Reply With Quote
Old 03-23-2018, 06:29 PM   #17578
Schlok
Schlok's Avatar
It'll see both of those engines.
Old 03-24-2018, 06:10 PM   #17579
2cnd chance
^ I agree.
Old 04-01-2018, 12:32 PM   #17580
Bhobbs
Bhobbs's Avatar
I test drove a new SS 1LE yesterday and I wasn’t all that impressed. It was nice and I could definitely feel the power difference but the car felt way smaller inside. My shoulder was up against the door and I was sitting on top of the bolsters instead of down in the seat. Plus, the exhaust seemed way more mild than the 5th gen NPP. I didn’t hear and growl or popping on decel.
The wheels are nice and I like the 6 pistons but that isn’t enough to get me to change over. If anything, I’ll just convert my car to ZL1 brakes and have them powder coated and add the 1LE emblem.
Old 04-01-2018, 05:56 PM   #17581
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I agree the exhaust seems tamer from the inside. But as both fly by from the outside, I feel like their about exhaust notes are about the same volume, Gen 6 being slightly higher-pitched.
Interior is, indeed, smaller.
Do you track your car?
Old 04-01-2018, 06:57 PM   #17582
Bhobbs
Bhobbs's Avatar
I haven’t gotten around to it. I’ve always wanted to but I’m trying to finish my Chevelle so my extra money goes to it instead of tired and brakes for the 1LE.
Old 04-01-2018, 07:24 PM   #17583
Mr. Wyndham
Old 04-09-2018, 08:12 AM   #17584
Bhobbs
Bhobbs's Avatar
Sorry but this refresh is just terrible all around.
"number z", 2014 700hp z/28, 3/27/2013, 75k, super de duper z thread, thread for the zed, what'z up?, where's our z/28, why no big z?, z/28 spring 2014
Camaro vs House? P. Ham 5th Gen Camaro SS LS LT General Discussions 82 05-20-2011 05:03 PM
House approves $2B more for 'cash for clunkers shank0668 General Automotive + Other Cars Discussion 3 07-31-2009 04:36 PM
3rd Annual Corvette Open House at MacMulkin Chevrolet-WELCOMES the ALL NEW CAMARO!! MacMulkin USA - New England 2 04-11-2009 09:16 AM
White House Approves $17.4 Billion Auto Loans to GM & Chrysler josh1147 General Automotive + Other Cars Discussion 97 12-29-2008 02:21 PM
White House says auto loans deal not imminent camaro5 General Automotive + Other Cars Discussion 11 12-15-2008 11:44 AM
