03-04-2022, 03:29 PM | #155 |
I've had my issue 2-3 years now. I've tried new starter, new battery, nothing wire related yet. Unfortunately, which is why I don't drive it much because my wait time to restart is 15 mins minimum with the hood up.
03-04-2022, 04:11 PM | #156 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Pull all ground connections ,1 in trunk and 2 in engine compartment and clean the paint off down to bare metal and add an extra grond cable from engine block behind alternater to the body where there is another small ground wire. Be sure to clean paint off there too.
This is what I did and havnt had any more issues!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
03-05-2022, 12:58 PM | #157 | |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
03-05-2022, 01:36 PM | #158 |
Drives: 2013 SS Inferno Orange L99 Join Date: Aug 2013
I had the slow cranking speed/ check engine light when starting hot after a few minutes of engine off. This has been a ongoing issue (many years) during the warm months here in Phoenix.
I found a cable that goes from the bellhousing on the starter side to the chassis structure where there is a bolt just below the heat shield. I purchased it from Gen5diy and there is a short video on the subject as well. Installation was very easy, just pay attention to the cable routing so as not to contact anything hot. This has cured the issue I have had with my car and no worries starting no matter the temperature. |
03-05-2022, 03:07 PM | #159 | |
03-05-2022, 04:33 PM | #160 | |
Drives: 2010 2SS/RS Camaro Join Date: Dec 2020
Open this posting and all should be clear https://www.camaro5.com/forums/showt...=399658&page=4 |
03-05-2022, 06:00 PM | #161 | |
It don’t come easy.
