01-14-2015, 08:02 PM | #141 | |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
01-14-2015, 08:06 PM | #142 |
Drives: 14 1LE Join Date: Mar 2013
What would our thoughts be if the brakes... Rotors, pads, and calipers (consumables of the system) were working correctly but the hydraulic system of actuating it wasn't? The brake pedal just goes to the floor... Would you find it absurd if it wasn't fixed on warranty? I'm asking because that system DOES work under the same kind of abuse, in fact we've seen pictures of people's calipers half melted off the car and that hydraulic system still functions correctly. The clutch hydraulics shouldn't be any different!
LMS Engineering
01-14-2015, 08:14 PM | #143 |
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav Join Date: May 2014
You think this thread is hot?...
... just wait till the presidential election season comes. |
01-14-2015, 08:18 PM | #144 | |
BeckyD Rocks :-)
http://www.camaro5.com/forums/showth...ht=clutch+poll http://www.camaro5.com/forums/showth...ht=clutch+poll I think if there would be another one, it would have to be separate from this thread and posted in the General Forums. This has been an issue since the beginning, but it appears that it's not widespread because there would be a hell of a lot more polls and a lot more threads complaining about the manual transmissions. It would be interesting if a new poll was started and to see what kind of results could be garnered from it, but the poll should include what year the model is from.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
01-14-2015, 08:40 PM | #145 | |
Drives: 2001 2500HD Join Date: Aug 2014
Again, what is it with people that think GM should pay to cover the detriments of their fun on a track? You realize GM (and any other car company really) would go bankrupt and/or have to price vehicles above what normal people would be able to pay for them if that were the case, right? Oh, and while I realize there've been a few isolated cases of this happening (let's be honest here, even a few hundred loud complaints on this forum is no more than a tiny drop in the bucket when you consider the hundreds of thousands of cars produced and sold) but saying GM should be on the hook for abuse is ridiculous. To the other guy that had issues at 1200 miles with no track use, I agree and fully believe your car should be fixed free of charge under warranty. That's why the warranty is there. The warranty is not there to fix problems that manifested after 75 laps around Laguna seca.
2001 ECSB 2500HD
01-14-2015, 08:41 PM | #146 |
Drives: 10 camaro ss Join Date: Sep 2014
Not for nothing, but if it was a clutch or clutch operating mechanism, your trans would grind every gear, since it applies/releases exactly the same no matter how fast or what gear you are in. I would guess you either have a worn synchro, which may or may not be a warranty concern ( i would lean more towards warranty), or a bent shift fork from trying to shove the shifter through the firewall on the 2-3 shift, which is not warranty. The only way to find out is a trans teardown. Usually dealerships will tell you if we pull it apart and its not due to abuse, so be it. But if we find a customer induced reason for failure, it may cost $blah blah. If you accept this cost, we will tear it down and see whats up
01-14-2015, 09:10 PM | #147 | |
Call Me"Doc"
Drives: 2014 2SS/RS 1LE BLACK Join Date: Apr 2009
If you never tracked the car, and had a problem at 1200 miles, what is causing the issue? Do you know exactly? A weak slave or master can cause gear grinding. Did you happen to take your "never tracked" car to a gm service provider and have it checked out? And if so, did they deny the warranty? If they fixed it, I dont really see your problem here. Other than your just pissed because you happened to get a car with an issue and some others didnt. None of my posts here have said the clutch system is perfect. Nor did I state that GM shouldn't warranty a car that's not tracked. Maybe you should read more of this thread, seeing that I never suggested anyone said "every M6 SS has this problem", just commented on a question someone else asked. To be honest, the hydraulic system in these cars is just effective enough for A to B driving. Some fail under normal driving, but how many of these cars have been built? Quite a few, obviously the fail rate isn't high enough to change the design. Think about it, if car makers redesigned everything that ever failed, every car would be perfect by now. The transmission in our cars are far from being a "shitbox". That's just nuts to think that.... Also, does this mean I can call you "Frank" now? |
01-14-2015, 09:21 PM | #148 | |
I agree with your statement that we're just drops in a bucket and this is why I beleve GM is unwilling to to rectify a known issue for the last 18 years. They've chosen to go the warranty route on those drops in the bucket. Maybe they see a cost advantage fixing the few instread of redesigning the system... All speculation of course but illustrates the point. The guy with no track time, having he same issue as the guy who does track,.. what difference does it make? It's the same problem. The fact that the clutch problem does happen on street driven cars only makes it that much more legit, and it should be warrantied.
LMS Engineering
01-14-2015, 09:21 PM | #149 | |
01-14-2015, 09:23 PM | #150 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
I am the last thing from a GM fanboy. BMW fanboy, sure, but GM has been the butt of more of my jokes than I can count. We are being told that this is a design issue. If that were truly the case, then all cars would be seeing grinding issues in all gears, all gears the time. They are not. This clearly indicates that the problem is with tolerances, suppliers, or user error. NOT design. If we're going to accusatory, let's be somewhat intelligent in our argument.
My thoughts on some things:
01-14-2015, 09:26 PM | #151 | |
01-14-2015, 09:35 PM | #152 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
The older people and the kids......they love our 1LE
01-14-2015, 10:00 PM | #153 | |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
Yes it sucks and you tracking your car is probably not even the reason you are getting the grind when you shift in high RPMs, but since they know you tracked your car they are going to use that against you to save them money. Even if they do end up fixing the issue, won't they just use the same parts again therefore causing you to have the same problems over and over? just upgrade the clutch and drive the shit out it!! and i did watch the video i see what you are saying..
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
01-14-2015, 10:10 PM | #154 |
Drives: 2010 Silverado. Stock height now Join Date: Oct 2014
Chrysler puts trail rated on their jeeps but will void your warranty in a heartbeat if they found you were heavy off-roading.
