05-28-2024, 03:40 PM | #15275 | |
Drives: 2023 Camaro 3LT RS Join Date: Aug 2019
It needs modified for the V6. More specifically, it needs cut on the top end. Other than that it's a crap shoot as to whether or not the screw holes line up. If they don't they're only off a little bit. Nothing that can't be fixed with a small file. Installation is replacing 4 OEM header bolts with those supplied. The supplied bolts are tapped to receive the small screws that hold the plate. |
06-03-2024, 12:08 PM | #15276 |
Gray Ghost
Drives: 24 Camaro 2SS Loaded Join Date: Feb 2024
Went to Auto Zone and walked by the paint so I grabbed a can, found some stencils and went to work. Easy Peasy!!
06-03-2024, 12:41 PM | #15277 |
US Army Retired
Nothing big but I have always liked the Alcantara armrest. So I got me one. The red matches my red knee pads and seat belt.
2002 WS6 #3392 SOM, 645 hp, 507 tq.
2023 2SS 1LE Shadow Gray Metallic A10, ACS side skirts, rock guards, Diode side markers, Roto-Fab, GM Performance black STB. Stock dyno 387 HP, 411 TQ. |
06-03-2024, 08:09 PM | #15278 |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
Oooh, that would be nice to rest the arm on...
Hmmmm.... |
06-04-2024, 07:43 AM | #15279 |
Took her off the trickle charger and went for a drive after a month of pause as I had been out of state. What a freaking fantastic car, it's crazy how good it is to drive even after 6 years.
06-04-2024, 04:45 PM | #15280 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Picked up Rotofab CAI - Hopefully fixed heat soak issue.
Picked up Wideband AEM controller - Hopefully verify AFR is where it needs to be. Seriously considering Meth/Water Injection next.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
06-04-2024, 06:53 PM | #15281 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Yearly oil change
Sent from my iPhone using Tapatalk Pro
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
06-04-2024, 09:36 PM | #15282 |
Agreed! Finally got mine for the first drive of the year after it sat in my garage since last November. It was like driving a new car again…but with a little more power…
